Coyotebrown
- Aug 12, 2021
New to the forum and rebuilding a lathe. I have a SB9C I’m rebuilding. While tearing it down I discovered the back gear (small gear) has one tooth broke off. I’ve seen the repair kit post and may go that way depending on the consensus of responses.
My question: How much of a problem or issue is one tooth on the back gear going to cause during normal use for a hobbyists lathe?
Thanks, any help/suggestions would be appreciated.
