Just recently bought an old South Bend 15" and I've got some questions I hope ya'll can help with. This is a 5' bed series 'O' dating from 1920 per the serial card. It seems to be in pretty good shape, looks like some bed wear (based on slide getting tight as it moves toward the tailstock - I suspect it's adjusted to be snug on the worn section which makes it too tight on the unworn area) but it doesn't seem too bad. Also got about 1/16" of slop in the cross slide lead screw. On the other hand it was cheap, works and seems in good shape so I couldn't pass it up. I've got a little sherline and had some experience with that along with some time on larger lathes in various classes and shops. My dad also has a 9" that we've worked with a bit but never gotten much into.
So, my questions:
1) What is the headstock taper / chuck thread? I find some info that says it's a sb specific taper and some that says a Morse #3 (I think). Likewise, some info says 2"/8 thread but I've seen a few other things too. I don't actually have the lathe yet to check it myself.
2) I'm going to need to get centers and a faceplate(s) for it - what other model gear will fit? I assume if the taper is a standard Morse it should be pretty easy to find centers, but if it's not I'd like to know what else will fit so I can search e-bay and such. Same with the faceplate.
3) How close are these units to the later 9" in construction? We have the 'How to restore your 9" south bend lathe" book and I'm curious how much of the info in that book applies to the big girl. I know the apron is different, but is anything else that different?
4) How do you adjust cross slide lead screw end play? As near as I can tell the majority of the slop I have is the screw moving, nut nut/screw wear. I assume there's a thrust washer/bearing somewhere that needs to be replaced.
5) One of the things I'd like to do is to make an adapter to use the steady rest we have for the 9" on this lathe. Anyone done something similar? How did it work? I was planning to build it up welding some plate together (making sure the surfaces with properly aligned of course) and do some creative machining/fab work to get the 'v' grooves setup.
~John
So, my questions:
~John
