Odd SB on local CL
Results 1 to 9 of 9
    Apr 2011
    Nebraska
    1,248
    1781
    366
    Default Odd SB on local CL
    I believe this is an old SB anyway. It's history is probably pretty questionable considering some of the odd things I see on it.
    Two things in this pic, the abortion of tooling sticking out of the tailstock and it looks like there is an electric motor attached to the cross slide screw.
    The main odd thing (not the oil reserve or the white wired thing hanging down) is the combination 2x4/large spring to provide belt tension? Oh, and the chuck that is over size for this lathe.
    Okay, more detail here. Huge oil reserve but only on one of the bearings? You can see how well that drill chuck sits in the tailstock, dangly thing with wires, and better shot of motor on cross slide screw.
    Finally, a better shot of the dangly wired thing. Looks like some kind of switch attached to a white cylinder maybe going to the cross slide motor? Not sure what is the intent with that.
    The text with the ad:
    Metal Lathe $500. Will easily fit in you garage or shop. Works as it should, smooth & quiet. Powered by 110 volts and a standard plug. Belt driven w/adjustable belt positions. 3 jaw chuck, power feed forward and reverse. Cutting tool holder. Comes with drilling chuck and a couple cutting tools. Delivery to your curb in Omaha available.
    Any comments?
    -Ron
    Jul 2008
    South Carolina
    665
    258
    409
    If it sits there for any length of time you can add more rust to the litany of issues.
    Aug 2014
    bainbridge island
    1,169
    233
    275
    does not look like any southbend i've seen yet.
    the motor on the cross slide looks similar to a type of gear motor used to drive variable transformers remotely, i have a couple of them.
    tailstock drill chuck arbor looks like something setup for a custom task as it sticks out far too far for any real purpose. probably a lathe setup for facing something.
    you will likely find the cross slide completely worn out. my lathe was used for a similar task, the bed had .022" drop but only over a 6-9 inch long section, with .003" concave in the cross slide. you might find the bed fine.. but the cross slide worn out.
    the gearing to drive the leadscrew appears to be of 20 degree pressure angle and the teeth appear to be larger than the gear teeth on the back gear. usually its the other way around.
    the lack of a reversing tumbler suggests the gearing is not original.
    the shims on the bearings are certainly not original.
    Jul 2004
    Houston, TX USA
    30,028
    Cross girts in bed casting say no, it is not a SB
    Apr 2011
    Nebraska
    1,248
    1781
    366
    Quote Originally Posted by johnoder View Post
    I am no expert but the girts and headstock appear to be ringers for this SB lathe made in the 1910-1915 range:
    Photo Index - South Bend Lathe Works - Un known model. 4’6” bed. Flat belt three speed drive. No quick change gears. Single axis auto f | VintageMachinery.org
  6. Likes tim9lives liked this post
    Jul 2010
    Virginia, USA
    3,459
    87
    638
    Oh yes, it is a Pre-WW1 SB. The serial appears to be 1286, which would be early 1912 or so.
    allan
  8. Likes swells liked this post
  9. #7
    Jul 2004
    Houston, TX USA
    30,028
    Sure glad there are some smart folks here
    I stand corrected
  10. #8
    Dec 2004
    Indiana
    1,607
    406
    150
    Allan, I agree, it appears to be a 1911 or 1912 Model 24, 9 inch Pedal lathe, I can see the treadle mount bar on the rear leg still there.
    Steve
  11. #9
    Nov 2007
    marysville ohio
    9,416
    2701
    6253
    Quote Originally Posted by kitno455 View Post
    allan
    For sure a very early SB. Motor riged on cross feed because it is pre geared cross feed. Left side oil port is open, may have had another rigged like the right hand one. note the wire on the back gear lever. The one I used in 6th grade metals class had the same feature. It would pop out of back gear at will.
