mcload
Hot Rolled
- Nov 5, 2007
- Houston, Texas
Hello and thanks in advance. I have taken my '46 Model A 9" apart once again for maintenance and new paint.
When I removed the spring-loaded pin that allows engagement of the half-nut lever, I noticed that it had a strange
configuration on the end.
There are two angles on the end of this pin; one is about 63 degrees, the opposite is about 45 degrees. (I will attempt to attach a photo). Has anyone noticed this on their 9A lathe during disassemble? Are the angles correct? Thanks!
View attachment 275727View attachment 275727
