Potential new 9A owner
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Default Potential new 9A owner
    Hello all, I'm on the verge of picking up a 1955 9A.
    Well tooled up with a Buck 3-jaw chuck, a 4-jaw, follow-rest, factory collet set, rack and drawbar.
    I haven't seen it in person yet but have a ton of pics.
    I'm a little concerned about bed wear.
    Attached are a few pics.
    Recognizing the difficulty of armchair assessment via pics I'd love some feedback on the bed wear any other thoughts about this machine.
    Some of the tooling
    Sep 2004
    Fort Worth, Texas
    2,182
    295
    194
    Pretty hard to tell from the pic. The old ROT is if you can hang a fingernail on that edge, it's suspect. Best way to check it (for me) is to mount a DTI on the tailstock, zero it at the far right (unworn) end and slide the tailstock with the DTI riding the face of that worn V-way up to the headstock. Write the deviation on the bed as it changes with a sharpie pen.
    That said, if the price is right, I'd take it with thoughts of finding a nicer bed sometime in the next couple years. Unless you are going to be making rocket parts, you can still get acceptable accuracy from a worn bed, especially if you aren't making long parts - long enough that the saddle has to move from worn to unworn areas as you turn the part. You either stay within the worn area (where most of the work is done) or you move the work out to the unworn portion by using a steady rest or turning between centers.
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Quote Originally Posted by Rex TX View Post
    Thanks @Rex Tx
    The seller is asking $1000 CDN but he thinks he has a 10Ē.
    Iím going to bargain hard as Iím not willing to pay that for a lathe that old and potentially worn.
    I have a line on a 1977 10K for $900 that I know is pristine but has zero tooling.
    Jan 2014
    North Carolina
    474
    17
    135
    I'd say that's not a $1000 lathe. Discount for the really, really goofy countershaft arrangement. Discount for the missing covers over the back gears which is a sure invitation for crap to get into the gear teeth. Discount for the missing end cover over the feed gear system, again a sure invitation for crap to get into the gears or more importantly your fingers!. Discount for the tailstock just thrown into the basket with other parts.
    The bed wear evident in the picture is probably the least of the issues with that lathe. As mentioned previously, bed wear represents a very small error in turning diameter which can usually be overcome by careful planning of the turning job.
    I'd say keep looking.
  5. Likes DavidR8 liked this post
    Sep 2004
    Fort Worth, Texas
    2,182
    295
    194
    Dobermann is right, that lathe has issues. That vertical countershaft mount is fugly, and you will be buying parts to replace what is missing or worn.
    Go buy that pristine 1977. Those are fast becoming unicorns. You can get going with minimal tooling, add more along the way.
  7. Likes DavidR8 liked this post
  8. #6
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Thanks gents, youíre confirming my gut feeling on the direction I should go.
    I was pricing out the missing parts and it was getting expensive fast.
  9. #7
    Feb 2015
    Florida
    535
    119
    I thought that you said he had all the gear covers (in some other post) for this lathe. It looks like you have all the drive parts to re-convert the drive back to horizontal. It also has a good tooling, including a collet setup, but 3C collets only go to 1/2". If you can get it for $7-800, it will be a good buy for you. My verdict on the bed is that it isn't pristine, but it also isn't all that bad for collet work up close. It also helps to get the price down.
    The 10k has the hardened and ground bed, which is a plus. A collet system for that goes up to 5/8" (6K), but is not included. The required tooling for the 10k will be costly.
    You can also check out the 9" locally, where you can actually check the lathe out thoroughly (check all gears for wear and missing teeth - look up into the QCGB and at the drive gears, check the tailstock for droop, check the cross-slide and the compound screws for slop) while the 10k is caveat emptor - what you see is what you get.
  10. #8
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Quote Originally Posted by SLK001 View Post
    I asked about covers and he doesnít have the domed one that covers the reversing gear train (Iím not sure thatís the correct term)
    If the 9 can be had for 700-800 Iím willing to do it.
    He also thinks itís a 10Ē so I have some leverage there.
    If he demands full asking price I wonít.
    The 10K comes with nothing, not even the other set of jaws for the 3-jaw so Iím basically buying a bare lathe. Oh and itís 3-phase so I need a VFD or a different motor.
  11. #9
    Jan 2010
    East Bay, CA
    194
    9
    What the heck. Get them both.
  12. Likes DavidR8, Yan Wo liked this post
  13. #10
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Quote Originally Posted by xeddog View Post
    If I had the space I would.
    Seriously though, getting both is not a bad idea.
  14. #11
    Sep 2004
    Fort Worth, Texas
    2,182
    295
    194
    Quote Originally Posted by DavidR8 View Post
    ....and this is how it starts.
  15. Likes DavidR8 liked this post
  16. #12
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Iíve read about this phenomenon. Never thought that Iíd be so close to the epicentre!
  17. #13
    Dec 2013
    Vermont, USA
    457
    6
    113
    Get the 10K, you will spend a substantial amount to get the tooling but you can do that gradually and there is a lot to be said for not perpetually trying to un-botch someone else's botch-ups, and that 9 looks like it was owned by someone inclined to botching things. 9's in less than wonderful condition are not scarce, pristine 10Ks are substantially more scarce.
  18. #14
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Actually in a completely unexpected turn of events an even better 10K turned up.
    A virtually unused, CL670Z. It still has the original scraping marks on the bed.
    I'm going to pick it up this weekend.
  19. Likes packrat2 liked this post
  20. #15
    Sep 2009
    Phoenix,AZ
    1,838
    2808
    472
    Well going by that BIG bore in the spindle I would 10L aka Heavy 10. Only downside is the rather short bed,but for most work not a issue.
  21. #16
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Itís a 10K by the catalog number.
    Iím waiting for the serial number.
  22. #17
    Oct 2015
    Virginia
    569
    19
    132
    Quote Originally Posted by JohnEvans View Post
    A few easy ways to tell a 10k from a Heavy 10:
    1. the spindle cover. On a 10k the whole thing flips up just like a 9". On a 10L only the center section
    flips up.
    2. The half nut levers look totally different
    3. The banjo on a 9/10k is a Y shape. It is straight on a double tumbler heavy 10.
    There are many more, but that's the easiest way to distinguish at a glance.
  23. #18
    Mar 2010
    Utah
    718
    58
    49
    Quote "Actually in a completely unexpected turn of events an even better 10K turned up.
    I'm going to pick it up this weekend."
    I think you just found a beautiful lathe, sometimes good things happen when you just keep looking for the right one....
  24. Likes DavidR8 liked this post
  25. #19
    Oct 2019
    CANADA
    British Columbia
    63
    115
    28
    Thanks @Packrat2, I was kinda bummed when I lost out on an auction of for a Hercus but finding this lathe is pretty darn awesome.
    Let the learning begin!
  26. #20
    Sep 2015
    Florida
    671
    5
    98
    Very weird...
    10k with a large spindle bore?
