Domodude17
- Aug 14, 2017
On my 9A, if you put an indicator against the cross slide and move it back and forth with your hands, there is approximately 0.040" of play. I know 0.007" of that can be accounted for by the acme screw itself moving back and forth (need a thicker washer). The rest of that would be coming from wear in the cross slide screw, correct? I replaced the cross slide nut very recently in the hopes that only the nut was worn.
