Quick Q1 - ball detent on sliding gear on 1929 wide 9 (heavy 10 style)?
Results 1 to 6 of 6
    Apr 2016
    398
    160
    166
    Default Quick Q1 - ball detent on sliding gear on 1929 wide 9 (heavy 10 style)?
    slowly piecing stuff together on my wide 9 project and I have a couple of Qs - this is the first.
    It looks like the gear that meshes with the large gear on the end of the QCGB can slide in and out to change the gear reduction from the spindle. Big clue is the "don't slide while lathe is turning" label on the gear cover Other one is the two grooves on the shaft it turns on.
    Both the large hole and the smaller threaded hole line up with the 2 grooves in the in and out positions.
    My guess is that there should be a ball bearing and spring in one of those holes that would act as a detent in each of the 2 positions. A 5/32 ball bearing fits in the threaded hole but there's barely enough room for a single coil of spring before there aren't enough threads to retain it.
    Any ideas?
    Oct 2009
    Northern California
    692
    145
    65
    The threaded hole is for a screw that holds a leaf spring that puts a bit of pressure on the ball bearing in the other hole .
    My heavy 9 was missing the spring and ball when I got it , so I made a spring out of a piece of hack saw blade .
    The spring needs not be very strong , just strong enough to keep the ball in the indent .
  3. Likes mattthemuppet liked this post
    Apr 2016
    398
    160
    166
    oh cool, thanks Peter, that makes alot more sense now. I'll rummage around and see what balls I have and fashion something up.
    Sep 2010
    moscow,ohio
    6,529
    675
    2267
    here ya go...
  6. Likes mattthemuppet liked this post
  7. #5
    Apr 2016
    398
    160
    166
    awesome, thanks. That's next or second on the list
  8. #6
    Apr 2016
    398
    160
    166
    worked a treat, thanks to both of you!
