Rare 1930s-40s South Bend Clone from Australia - any idea of origin?
Likes Likes:  0
Results 1 to 4 of 4
    Apr 2019
    AUSTRALIA
    Default Rare 1930s-40s South Bend Clone from Australia - any idea of origin?
    Hi Folks,
    I have recently com into possession of what appears to be a Southbend clone, Badging states supplied by DEMCO - gear cover states 4 1/2" bench lathe. the Serial is CUY149 - I have no Idea what the Y means, but C type and underbench drive.
    Doing some research I came across lathes.co.uk which had a Sheraton page, however this does not look like a Sheraton headstock, so maybe an earlier demco import (imports around the time of the late 30's were horrendously expensive so). or maybe an early prototype, judging by the finish on the castings.
    Someone at some stage did a shocking job of "repainting" with some greenish hammer tone straight over dirt/grease/etc and what appears to be southbend gray.
    overall, apart from some surface rust under the paint it looks in pretty good nick. Bed has usual wear and looks to have casting faults in the headstock.
    Any ideas of origin?
    Hpurple
    Aug 2014
    AUSTRALIA
    493
    5
    128
    heya - might be worth a post over here as well: METALWORK GENERAL.
    As for the lathe, I've not seen one like it - have you scanned lathes.co.uk ?
    Sep 2010
    moscow,ohio
    5,708
    555
    1806
    Almost doubtless is it a Demco badged Sheraton copy of the first pattern workshop type SB9" under motor drive lathe.
    Feb 2015
    Florida
    278
    48
    Quote Originally Posted by iwananew10K View Post
    So it is a copy of a copy of a copy?
