Speedy64
- May 26, 2012
- Connecticut, US
Hi Gang,
I've hit (what I think) might be a snag with my rebuild on my old 9a.
Everything was going fine until I took the rear horizontal drive unit apart that holds the motor and the counter pulley.
The actual shaft on the drive side (left side if you were looking at the lathe from the front) is scored really badly on both the shaft itself and inside the orifice of the drive unit on the lower end of the ID, and no it isn't the one that has bushings pressed in.
I'm not so super concerned with that inner, lower ID as I am the actual shaft.
MY OCD brain is all over the place and I'm literally losing sleep over this, yes I'm that lunatic.
These are all of the conversations I'm having with myself.
"Leave it alone because that mechanism is only there to drive the pulley on the front spindle so who cares. It will never affect anything your cutting or the tolerances. Just fit one of those large screw in oilers that holds lots of oil or grease the hell out of it and call it a day."
"Somehow get that pin (that does not want to come out) out of the assembly and take the shaft to a local machine shop and have a new one made."
"That's fine but then what do you do about the scoring inside the part of the assembly that it goes through?" Well I'm not that worried about it, but should I be"
"Take some fine Emory cloth and spin the shaft in the cloth until the ground up material is smooth. Yeah but what if I take off too much material, and I create more of a clearance, and the thing flops around in the assembly like an apple in a barrel."
As you can all clearly see, I'm driving myself nuts over this and I don't even know if I should be.
I attached a picture of the offending shaft.
For all of you that have either suffered with this in the past or know how to deal with it, I would really appreciate your thoughts.
Thanks in advance...
P.S., I'm not quite sure how the pictures on the internet look to you but trust me it's gnarly and the grooves are very deep.
