Point of Diminished Returns?
Just my 2 cents.
Seems to me that there is a point of diminished return when it comes to professional drill bit sharpening.
I know there is when it comes to table saw blades and chain saws. It costs just as much to have them sharpened
as it does to purchase new...which is why I have so many of each.
Same is true (for me) when it comes to drill bits. On the small fractional stuff, I just toss and buy new.
And when I do, I always buy 2 or 3 extra. I inherited a set of drill bit organizer drawers in fractional, letter,
and number drill bits. (I haven't started metric). The number and letter drills are a bit spotty here and there,
but I keep the fractional well stocked; and usually with plain jobber drills. (Don't know that I believe all the
claims on "Titanium" stuff)
I also keep an index holder that I use for the fractional sizes, and it goes up to ½". I use these for general purpose
on the drill press and the lathe. I will only go to the grinder with a bit if I don't have a replacement ready to grab.
But yes, for the big MT drills, I will always send out for sharpening. (Although I can get by in a pinch, my drill bit
sharpening skills leave a lot to be desired!) :-)
I know this is pretty common knowledge, and correct me if I'm wrong, but my Dad taught me that when using a drill bit in
a press, the sharper of the two flutes will always "dominate" the cut, and can lead to a slightly curved hole. However,
when a bit is stationary and the work piece is turning (such as on a lathe), the bit is always being forced to center
of the workpiece regardless of flute sharpness, and therefore, it will not drill a curved hole. (In theory, of course).
So in regards to "precision sharpness", it makes a difference whether a bit is being used in a press or a lathe.
And I ALWAYS start with a hole drilled with a center bit usually followed with a good pilot hole..no ifs, ands, or buts.
But yeah, the big stuff (which I don't use very often) I will send out if need be.
PMc
PS: A GOOD drill bit sharpening device (in an enclosed sharpening station room) makes all the sense in the world.
I've just never seen one in action. What do the "pros" use?
View attachment 300649 View attachment 300650
