Reliance Motor on SB13 - Missing a part?
Results 1 to 11 of 11
    Jun 2021
    Wisconsin
    16
    Default Reliance Motor on SB13 - Missing a part?
    I have been refurbishing a South Bend 13 for about a year now. I have the lathe running but am not satisfied with the sound of the motor. There is a high-pitched whine that I can't hear, but it bothers the heck out of my wife as it seems to penetrate through the whole house. (I mostly can't hear this sound because of loss of high-frequency hearing, but I can record it and see it in spectral analysis.)
    The motor is a Reliance (later bought out by Baldor) 2HP 3PH. I am running it with a cheap VFD from Amazon (XSY-AT1). I don't have a means of powering the motor other than through the VFD. I have taken it back out of the lathe and have it running with the VFD on my bench. I have verified that the noise comes from the motor, not the VFD or any other part of the lathe.
    I originally thought the motor bearings were OK and didn't replace them. However, since I have this noise, I decided to preemptively replace them - just in case that makes a difference. When I pulled the bearings out of the motor, I discovered that one end had a spring and a plate in the bearing cup, while the other end has a spring, but no plate. Here are the parts I found:
    http://www.mikelitzkow.com/wp-conten...114_094424.jpg
    I can't find any parts diagrams or other information on this motor. Here is the data plate:
    http://www.mikelitzkow.com/wp-conten...2178898770.jpg
    My question is whether anybody knows if both bearings should have a plate associated with the spring? Maybe somebody took the motor apart before me and lost that part? Maybe the extra end-play causes the noise? Or maybe, it's time to "bite the bullet" and buy a rotary phase converter? Any and all advice on how to get rid of this noise will be appreciated.
    Nov 2006
    Camarillo Ca
    541
    48
    126
    Spring washers are normally only on one end (rear)
  3. Likes mlitzkow liked this post
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,494
    3432
    2193
    Without hearing it, my guess is its the high pitched whine that all/most vfd's make. Maybe better units don't do that, but in my experience in shops that use them, I can always hear it. I realize you say its coming from the motor, but its caused by vfd. I could be wrong, see if you can power it off real 3ph somewhere and see if its still makes the noise.
    I run an rpc, not happy with the noise it makes, but will take it over the high pitched whine that bores into my brain.
    Jan 2014
    North Carolina
    562
    27
    175
    The sound you don't hear is likely caused by the VFD. They all contain high frequency oscillators which oscillate in the range of human hearing. If you look at the instructions for your drive you'll probably find a setting which will allow you to change the frequency of the oscillator. You can usually move the frequency higher or lower. If I recall properly, there are some performance issues associated with going to higher frequencies but you could try that or you could set it lower and perhaps your household might find a lower frequency less annoying.
    The sound may be coming from the drive itself or it may be coming from vibrations set up inside the motor--either windings or laminations vibrating at the drive frequency. It's possible you could reduce the sound by putting some sort of blanket over the motor but that may interfere with cooling if you're running the motor under heavy load.
  6. Likes neanderthal mach, Gordon Heaton liked this post
  7. #5
    May 2013
    georgia
    99
    22
    Go for the rotary converter if you can but although we scold the static converters, i ran my tech school 1973 13" SB with Reliance 2 hp motor for 16 yrs without a glitch on a Phase-matic and it was plenty happy. PM if you want more insight regarding this setup. I have two other Industrial LATHES still running the same til I finally get my HD rotary converter up and running .
    Johnny
  8. #6
    Jan 2005
    Victoria, Texas, USA
    4,985
    3788
    1466
    I have a 1 HP Reliance 3PH motor on my vertical bandsaw powered by a TEAC VFD. It does make a wine noise, its not loud but you can hear it. I would suggest you go thru all of parameters on the VFD amd make sure they are set properly. The noise should not be so loud you hear it thru out the house.
  9. #7
    Jun 2021
    Wisconsin
    16
    Really good to know! Thank you.
    Quote Originally Posted by dalmatiangirl61 View Post
  10. #8
    Feb 2004
    peekskill, NY
    27,825
    6609
    Quote Originally Posted by 4GSR View Post
    TEAC made drives?
  11. #9
    Jan 2005
    4,985
    3788
    1466
    Quote Originally Posted by jim rozen View Post
    TEAC made drives?
    Alright, I can't spell worth a sh^t. You know what I mean...
  12. #10
    May 2020
    Minnesota
    601
    243
    260
    Change the carrier frequency on the drive. Factory default is probably 4kHz. 12 or 16kHz will be less annoying.
    Nicer drives can be configured to add randomness to the carrier frequency (e.g. white noise) to further quiet it down.
    Or install a single phase motor.
    Thermite jumping in to suggest a $2,000 DC motor and drive in 3... 2... 1...
  13. #11
    Nov 2008
    2,858
    21
    774
    Get a sond level app for your phone.
    Many different ones.
    They can show frequency and level.
    Then use your phone to locate the sound that you cannot hear.
    It could be the windings in the motor reacting to the carrier.
    A low dollar VFD may NOT have suitable line filtering and may be causing the windings in the motor to vibrate causing the noise.
    A filter may greatly reduce this noise and instalation is simple, it just goes between VFD and motor.
    Other folks who do this more should be able to provide suggestions for size and type.
    Sent from my SM-G781V using Tapatalk
