Restoring South Bend 10L lathe made around 1945
Results 1 to 6 of 6
    Aug 2019
    North Carolina
    Default Restoring South Bend 10L lathe made around 1945
    I am restoring a South Bend Lathe Catalog # 8187 RN S/N 126915 DWW 10L. Made around 1943 I'm trying to buy a book showing expanded views of how the various parts of the lathe were assembled. Main interest is the carriage, tool post and taper attachment areas.
    Help as to what books contain this type of detailed information and where to purchase the books would be appreciated.
    Oct 2015
    Virginia
    552
    18
    127
    This should help. Copy and paste as necessary if it doesn't link. You will need adobe to open it.
    http://www.neme-s.org/Shaper%20Books...s%20Manual.pdf
    The book off eBay is good also and walks you through some of the processes in order.
  3. Likes michiganbuck liked this post
    Aug 2019
    North Carolina
    Quote Originally Posted by hsracer201 View Post
    Thanks for the info. I hate to admit it but I took the cross feed and taper attachment apart with out taking pictures and now I'm having trouble remembering where all the thrust washers go. Hopefully this book will have expanded views that show all of that.
    Thanks again
    Jan 2019
    North Carolina
    228
    26
    39
    Quote Originally Posted by don crowe View Post
    Thanks again
    In order from the rear side of the taper attachment:
    Washer/bearing/washer
    Taper sleeve
    After that depending on what setup you have, one goes between the graduated dial and the dial bushing. The last one goes between the gear face and the end of the dial bushing.
    The last two are possibly not included on your machine. If you want a picture of an actual assembly apart and laid out how it goes together I’ve got two on the workbench right now.
    Aug 2013
    809
    491
    216
    Here's the ebay book (and felt kit) hsracer201 referred to:
    South Bend Lathe Heavy 10 - Rebuild Parts Kit & Illustrated Guide: Model 10L 10R | eBay
    May 2019
    Maryland
    11
    Sounds like you have a great lathe. I have a 1947 South Bend Heavy 10L
    S/N: 182564
    Bench Number: 1643-3D-1035
    Bed Length: 3 ½
    Catalogue Number: 187ZN
    sb-lathe-side-view-1.jpgI have rebuilt the headstock bearings,have had new cross slide and compound screws made, am getting ready to make a pair of large dials. If you need help or have questions let me know.
    Frank
