70chall440
- Jul 15, 2019
I have an issue wherein the rear (small) bearing in my 2-H was getting very hot. I did what the manual suggested but determined that there was an issue, so I removed the rear cap to discover that the expander was not seated into the slot of the shell. I cannot say my issue/s were this exactly but its definitely something I need to address.
My question is this, how do you remove the spindle gear? The manual says gear puller or arbor press but there isn't any room between the gear and the take up collar. The only conclusion I could arrive at is that you pull on the take up collar/ring after it is unscrewed as far as possible but I wanted to ask.
I googled this issue and watched more SB videos than I care to admit and read a number of comments on forums to include this one but have not found an answer.
As to the bearing getting hot, I suspect it was not getting lubrication as I pulled all sorts of crap out of the tube. I intend to remove the entire spindle but do not plan to completely disassemble it if I don't have to. The rear (small) shell has some deformation where the expander was pushed down into it; it appears like it was in correctly once but somehow came out. When this all began, I followed the manual and attempted to tighten the expander screws which had no effect, however upon disassembling it I discovered that the cap screws were barely finger tight. If I could figure out how to get the gear off I would try and save the shell (also need to do a needle bearing conversion because the fiber board has seen better days).
Any/all help is greatly appreciated.
