SB 16 - New to me, tell me what this thing is. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 21 of 21
  1. #21
    Sep 2019
    Michigan
    10
    Quote Originally Posted by markz528 View Post
    Looks a lot like my lathe. Mine is a 16 inch 6 foot and is a 1969 vintage.
    I do believe that those lathes came with 3 hp motors - at least mine did. I went back to a 3 phase motor to have the variable speed. I would sell my 3 hp single phase motor with contactors (makes the motor reversing).
    My pulley has a bad groove so I run 3 belts. One would thing that 4 belts is overkill, but it really needs the 4 belts for starting even with the vfd. The pulleys are small and they slip very easily during starting.
    I have been searching for a new pulley but have thus far struck out.
    Attachment 268165
    All the catalogs I've seen recommended 3/1.5HP but I gather motors were sold separately and people installed whatever they wanted. I've got a 2HP single speed 220/3-phase bolted up now - I did have to lift the lathe to pull the old motor and push the new one (new to me anyway) under the cabinet; the VFD should be here today.
    Removing the pulley from the original motor was a little dicey. I don't have acetylene and didn't have high hopes for propane but a bit of heat on the pulley and oil on the shaft freed it without much drama. The motor appears to have a date cast into the housing - Jan '59 So I'm guessing the lathe was probably delivered within a year or so of that, I still haven't found a serial number.
    The spindle bearings feel sticky to me; once it's moving it rotates freely but if you let it stay still for a second, it takes more force to start it by hand. I guess this is just what happens when the oil film breaks down while not moving - I assume this is the nature of bushings and it's normal.
