Sb 8183 c
Torchman
May 20, 2021
Can I raise headstock on this model?
Not bought yet but I need 8.5 min. To ways. (Slow set up multi pcs. Boring
On faceplate ) Clamped. Did this on
150 Y.O Prentice Bros.
Wish had it back. Thanks in advance
In a hurry. Want to be there first
T
Torchman
It could be a forties 14 1/2 Toolroom - 14 5/8" diameter actual capacity
You raise it by making yourself some raising blocks - one for flat way and one for vee way
Then you clamp it down with the stock straps and longer bolts (these hide under the HS)
Then you attend to stuff like getting the feeding/threading gear train to mesh again - and if the belt adjust runs out you get a new longer belt
If you need the TS higher, do that also - in whatever way suits its construction
If you don't regularly make stuff for set-ups, now is a good time to start doing that
