Hi all,
I needed a lathe to fix my tractor and I got this off craigs list for 500 bucks.
It resembles some of the south bend lathes I have seen, but it has no serial on the ways and has a tag that says American Machine and Tool Co Royersford PA and a serial on that tag of 420
It has a single tumbler (82-r?) quick change gearbox, but it appears to have been hacked onto the lathe using some aluminum angle as there is no holes or room for them on the lathe for the vertical mount screws normally used on the box to connect it to the lathe.
It uses a banjo with a cast of 9-630 but I think this was also added to support the unsupported gear box. Supposedly that banjo is used by the 9 inch junior lathe ?
The wooden feet under the metal feet obviously are there to allow the quick change handle to work otherwise it would hi the table and break off.
Any ideas on what it is ?
