The SB13 rebuild has started.
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    May 2019
    CANADA
    Ontario
    36
    22
    Default The SB13 rebuild has started.
    I'm a little late posting this, but wanted to share my enthusiasm in starting the rebuild of my newly acquired SB13.
    Decided to start with a small and relatively easy item, the tail stock. Attached are a couple of photos showing
    before and after. The finished product now sits in a prominent place near to the lathe to inspire me to carry on.
    The taper attachment and compound have since been stripped down. It's amazing what one discovers that needs either
    TLC or replacement as the tear down progresses. I've already found a missing tooth on the idler gear and a cracked
    tie rod bracket belonging to the taper attachment. The cross slide screw was installed by some heavy handed mechanic
    and was a bummer to take apart. The cross feed crank had actually rotated on the screw and the locking pin in the
    crank had managed to pop out of the bored slot. The crank was then able to rotate on the shaft dragging the locking
    pin along with it as the crank turned. I can't figure out how that could happen. Some people's kids eh? The CF screw
    and nut was fairly worn, so I've ordered a new set form the member here on PM who makes them. So far, it's been an
    enjoyable project and I look forward to seeing the rest of the lathe match the tail stock. More to come in a week or so.
    Raydel.
  2. Likes Kevin T liked this post
  3. #2
    Mar 2019
    North Carolina
    7
    What year is your lathe? Mine is 1965 vintage, same as me.
    Dec 2017
    New York
    174
    29
    65
    I would highly suggest you purchase this rebuild kit:
    South Bend Lathe Model 13" ● Full Rebuild Package ● Manual, Felts, Oil, Grease! | eBay
    I got the felt kit and book (didn't buy the lubs since I already had them). The book is great and replacing the oil wicking felts and seals should be done to properly maintain your machine. If he doesn't currently list a kit without the lubs I would imagine if you contact him via eBay he will list one for you.
    No affiliate, just a satisfied customer.
    Ted
    Jun 2019
    14
    i'd be curious to hear a bit more detail about your tailstock rebuild. i just acquired a heavy ten that needs some love, seems to be about a 1970 model. tailstock is kinda beat up, i can feel that inside of the quill taper is kinda scored up. thanks.
    May 2019
    CANADA
    Ontario
    36
    22
    Quote Originally Posted by Zeb1 View Post
    According to my serial number on wswells site, 1965.
    See here: http://www.wswells.com/sn/sn_db.htm
    May 2019
    CANADA
    Ontario
    36
    22
    Quote Originally Posted by weissman42 View Post
    The taper in my quill has a light amount of scoring too. I've ordered a set of morse taper finishing reamers (MT3 & MT4) from an eBayer in the Ukraine, relatively inexpensive, should be here any time now. The backlash between the acme screw and nut in the quill is minimal, but I may do something about that down the road. Too much rebuilding still ahead of me to get sidetracked with these little details. :-)
    May 2019
    CANADA
    Ontario
    36
    22
    Quote Originally Posted by Technical Ted View Post
    Ted
    Hi Ted:
    I did purchase the felt kit and book, it arrived last week. Lots of interesting reading.
    I currently have an SB9A, been using it for the past five years, so I have the oils as well.
  9. Likes Technical Ted liked this post
  10. #8
    Sep 2010
    moscow,ohio
    6,394
    653
    2132
    What are you going to use an MT4 reamer on?
    be very gentle with the MT3 in the tail stock quill, turn by hand only, don't try to make it look like new, just knock down any burrs or high spots.
  11. Likes jhruska liked this post
  12. #9
    May 2019
    CANADA
    Ontario
    36
    22
    Quote Originally Posted by iwananew10K View Post
    I'm not going to use it on anything at present.
    The eBayer was selling reamers in pairs.
    I already have a MT2 that was purchased to clean up the TS quill on my SB9A, so I opted for a MT4. Figured someone may have use for one somewhere and I can pass it on.
    Thanks for the reminder to go gently with the reamer.
    Ray
  13. #10
    Jan 2019
    North Carolina
    229
    26
    40
    Quote Originally Posted by Raydel View Post
    Ray
    I might have a use for that MT4 reamer if you wanna let it go! (I'd also have a use for that MT3 reamer but so much shipping!)
  14. #11
    May 2019
    CANADA
    Ontario
    36
    22
    Quote Originally Posted by naru View Post
    Hi Stephen:
    Now that I've stepped up to a MT3 size lathe, I don't forsee the need for a MT4 reamer, so I'll give some thought to passing it your way. For the time being, I'll hang onto the MT3. If I find it's just sitting there gathering oil��, I'll give you a shout.
    All the best,
    Ray
  15. #12
    Jan 2014
    North Carolina
    524
    20
    158
    Oh be careful with that reamer in the tailstock. DO NOT free hand that thing in the ram. Only run it centered on a 60 degree center in the headstock and do not try to get a brand new fresh surface with it. Use it to clean up what's there and you might want to try it on something besides your tailstock ram first to make sure it's accurate and correct. If you cut the taper in the tailstock incorrectly your going to be in a lot of trouble.
  16. #13
    Sep 2010
    moscow,ohio
    6,394
    653
    2132
    I cannot agree with using it on a center in the headstock....that would assume *perfect* alignment of the tailstock with the head, a condition that is exceedingly rare in a used machine, and if not in perfect alignment would cantilever the reamer so that when turned it would essentially become a single flute cutter and cut that same misalignment into the tailsfock quill, making the taper egg shaped to some degree.
    The goal is not to cut ANY of the original surface,only to knock down high spots.
    as it seems it's not Ray's first rodeo, I expect he will be fine.
  17. Likes Derek Smalls, Raydel, Rudd, Demon73 liked this post
  18. #14
    May 2019
    CANADA
    Ontario
    36
    22
    Thanks to those with concern for my tailstock quill, very considerate of you.
    For the past 35 years, I've been building anesthesia equipment (I put people to sleep) , that's why I purchased my first lathe back in the day, an Emco compact 5. Although I make no claims to know much about anything, as most of you proficient machinists, one does eventually develop a keen sense of "feel" when working with hand tools. Iwananew10k seems to have read me correctly, I'm not going to botch my quill.
  19. #15
    May 2019
    CANADA
    Ontario
    36
    22
    Follow up on the reamer topic:
    My two reamers arrived in the mail today. That MT4 is a huge sucker, think I'll part with it. I took the MT3 out of the package and wiped it down, a quick visual inspection for any deformities, then carefully inserted it into the tail stock quill and hand turned it to get a "feel" of what was happening. Several passes were made with increasing force on each pass, using my thumb to increase pressure inwards. I was using a small adjustable wrench as a handle. The TS quill on my SB13 is very hard, even after four or five passes, hardly anything came out save a few crumbs from the cleaning up residue of very light galling. You could tell that no real cutting was going on inside. I was pleased with the results, the innards of the quill felt quite a bit better and yes, the taper on the drill chuck locks into the fresh quill very tight. All in all, it wasn't brain surgery.
  20. Likes iwananew10K, Sachmanram liked this post
  21. #16
    Feb 2015
    Florida
    814
    228
    If your TS is hardened, then what came out was most likely from the tooling that was mounted and spun in the quill. What does the inside look like now?
  22. #17
    May 2019
    CANADA
    Ontario
    36
    22
    I'm not absolutely sure its hardened. The reamer didn't remove chips, just crud. But it left a shiny surface on 75% of the quill. There definitely is some galling in there, a half inch band about 3/4" in and another quarter inch about 3" down inside. For us who pariently care for these vintage machines, these sort of things pains the soul.
  23. #18
    Jan 2019
    Hawaii
    699
    304
    181
    I keep admiring your work on that tail stock and wanted to ask how you got the shiny parts looking so good? Especially the collar in the pic. The parts manual I have calls that the tailstock nut.
  24. Likes Raydel liked this post
  25. #19
    May 2019
    CANADA
    Ontario
    36
    22
    Quote Originally Posted by Kevin T View Post
    Kevin:
    It's quite easy to do. I have a SB9A that's doing a lot of the grunt work. The entire TS was stripped down to bare metal. At that stage, the tailstock nut was chucked up in the 9A on the hex nut end and spun at medium speed. I then used two or three grades of paper to take the rust off and get a decent clean metal finish on that surface. If you have minor dings in the metal, light use of a fine file will take them out before the papers. The final grind is with a fine emery cloth. Followong the emery, I use a 6" grinder that has two cloth buffing wheels spinning at 3400+ RPM. One wheel has a brown compound and the other wheel (the final step) has a white polishing compound. Two to three minutes on each wheel will get you there. Total time from start to finish, approx ten minutes. The TS hand wheel was chucked up in a four jaw and the file was used as a first step to remove rust and some very minor dings, rest of the procedure was the same. Try it, you'll be pleased with the results.
  26. Likes Kevin T liked this post
  27. #20
    Jan 2017
    Washington
    400
    143
    For the past 35 years, I've been building anesthesia equipment...
    That sure is a small field. Do you happen to work for Draeger? I think that their Canadian office is based in your neck of the woods. I think GE has a satellite office and maybe Benson?
