SB9A restore and retrofit 3 phase/VFD - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 63 of 63
  1. #61
    Apr 2019
    38
    Deciding to move ahead on a new motor pulley, here is a double pulley for a Poly V 6 rib direct to spindle cone pulley. The low speed pulley is 1.9" diameter and the high speed pulley is 2.4". This gives roughly 500 rpm in low gear and 900 rpm in high gear. I thought the 2.5" round bar stock was big enough but the larger pulley could have been 3.0" to get over 1000 rpm. I could always re-configure the VFD for over 60 hertz I suppose.
    Since the motor needs to be shifted over at least an inch to allow the pulleys to line up, now maybe a good time to re-build the motor mount.
  2. #62
    Sep 2010
    moscow,ohio
    6,469
    664
    2202
    that motor will have no trouble at 120HZ...certainly not at the 100HZ I think your VFD will go to.
    glad to see you are still experimenting.
  3. #63
    Apr 2019
    38
    Up thread in a video, I detailed a hall effect tachometer with the magnet attached to the small cone of the spindle pulley. At the time, I would do a mental divided by 5 when using the back gears. Well, it wasn't long before comments about using the back gears made me rethink the issue. My solution is to mount the 3/8" magnet in the spindle takeup nut. A 3/8" end mill was used to mill out a hole in the nut and the magnet was press fit into the nut. Now I have true spindle rpm's.
