BobsYourUncl
- Nov 11, 2020
- Mindwest
I recently acquired a SBL 10K manufactured in 1971. Overall it is in good condition; very little wear, no broken gear teeth, no unearthly noises, and no vibrations. Most everything was stiff from old oil and everything is now oiled with the correct A,B,C,W oils. From the picture you can see it can cut chips.
Before I start making parts I wanted to check all the capabilities of the lathe. When I increased the speed of the lathe (no part, no cutting) with the Variable Speed Drive (VSD) , it increased speed nicely to 1100 rpm, but then it started to bog down (audibly) so i cranked the speed back down to 400rpm.
I then hooked up a clip ammeter and ran the speed up while measuring (IR) casting temperatures on the lathe. The only temperature that went up notably was the headstock bearing casting (near the chuck).
Time Rpm Amps HdStck Casting (degF)
6:26 450 7.6 76
incrspd 550
6:28 550 7.7 77
incrspd 650
6:30 650 7.9 80
incrspd 750
6:32 750 8.1 87
6:34 725 8.6 99
6:36 730 8.4 104
6:38 730 8.4 107
6:40 710 9.0
6:41 500 10.4 122
What is causing the temperature rise? I suspected the flat belt load was too high. I adjusted the turnbuckle
to it’s shortest length ( least belt load) and repeated the test.
7:16 450 7.7 76
incrspd 550
7:18 550 7.8 77
incrspd 650
7:20 650 8.1 79
incrspd 750
7:22 750 8.3 83
7:24 720 9.4 90
7:26 750 8.1 91
7:28 750 8.0 91
7:30 753 8.0 90
incrspd 850
7:32 850 8.2 90
7:34 850 8.2 91
7:36 856 8.2 92
incrspd 950
7:38 950 9.3 108
decrspd 550 heard motor load increase
7:40 550 8.3 116
It seems that by backing off the flat belt tension I was able to keep the headstock temperature from spiking until 950 rpm (first test it spiked at 750 rpm). This leads me to suspect that the belt tension is not adjusted properly.
Question 1: Does anyone have the 10K flat belt adjustment procedure? (I checked in ILIONs “A guide to Renovating……” and I could not find it there.)
Speaking of belts, there are 2 V-belts for the variable speed drive. It seems the previous owner replaced the top belt and the lower belt is OEM (PT2817KK1).
Question 2: Does anyone know if the original VSD had both belts (top and bottom) the same?
The V-belts seem loose to me. When I compared the distance between the belts as they sit versus if I took up the slack with my forefinger and thumb, the belts get closer together by about 2-2.5 inches. The motor is at it’s most extended so I can’t take up the slack by sliding the motor in its slots. I suspect the previous owner replaced the top belt with the wrong size belt and when he couldn’t move the motor anymore, they adjusted the turnbuckle.
Question 3: What is the original v-belt tensioning procedure? (I checked with Hi-Lo Mfg (provider of the VSD) and they had no more information to offer.)
Thanks in Advance. I’ve perused the forum and seems there is a wealth of experience in all things South Bend Lathe. I’m looking forward to learning from you and sharing my experiences with this 10K.
BobsYourUncl
6:26 450 7.6 76
incrspd 550
6:28 550 7.7 77
incrspd 650
6:30 650 7.9 80
incrspd 750
6:32 750 8.1 87
6:34 725 8.6 99
6:36 730 8.4 104
6:38 730 8.4 107
6:40 710 9.0
6:41 500 10.4 122
7:16 450 7.7 76
incrspd 550
7:18 550 7.8 77
incrspd 650
7:20 650 8.1 79
incrspd 750
7:22 750 8.3 83
7:24 720 9.4 90
7:26 750 8.1 91
7:28 750 8.0 91
7:30 753 8.0 90
incrspd 850
7:32 850 8.2 90
7:34 850 8.2 91
7:36 856 8.2 92
incrspd 950
7:38 950 9.3 108
7:40 550 8.3 116
BobsYourUncl
