securing 8 inch pump on lathe - what am i doing wrong?
Results 1 to 12 of 12
    Jul 2018
    33
    14
    5
    Default securing 8 inch pump on lathe - what am i doing wrong?
    Hi all - so I have a pump from my automatic transmission im trying to cut, its aluminum. I have a nice bit that leaves a very smooth surface but it is a very interrupted cut -
    Issue is when I get to the mid/outer section i think the interruption is throwing off the centering which takes me a while to get right (under 1 thou) and makes the bit dig
    How can I attach this darn thing so it wont move on the chuck? Im only taking about 5-8 thou at a time, tried med and slow speed on the pulleys..
    Jul 2004
    Houston, TX USA
    32,464
    You need a fixture / fixtures - face plate-like
    Show us the back - maybe we can suggest what to attach to.
    May even result in a fixture that you mount the item on before you screw the fixture on the spindle nose
    Hint - a hard wood fixture (or "attaching piece") with lots of contact area will help deaden things out
  3. Likes sfriedberg liked this post
    Jan 2019
    Hawaii
    989
    411
    299
    Also the farther away from center you are the more you may have to deal with the slop in your dovetails etc due to more forces. Are yours adjusted well?
    Feb 2004
    Traverse City, MI
    3,437
    179
    175
    I have attached plywood to a face plate and then screwed the work piece to the plywood.
    Aug 2015
    Illinois
    1,755
    1373
    750
    We really need to see what the back of the part looks like. How are you holding the part? 3 jaw, 4 jaw, or faceplate?
    Feb 2007
    St. George, Utah
    1,491
    999
    1039
    It appears you are gripping by expanding the jaws inside the part. Is the surface you are gripping machined perfectly straight? Are your jaws sloppy in the tracks? Is the condition of the jaws good? And, are you facing the whole casting or just the center section?
    My solution is to make a mandrel with a flange, to fit that center hole. Then chuck up in the conventional manner.
  8. Likes Kevin T, Illinoyance liked this post
  9. #7
    Jul 2018
    33
    14
    5
    this is the back - all i could do was use the center hole. Had it in a 3 jaw for the facing, then switched to a 4 jaw for the pocket cos its off center.. I should have prob just used the 4 jaw - more clamping force but it is what it is -
  10. #8
    Feb 2007
    St. George, Utah
    1,491
    999
    1039
    It would help to see the backside without the shaft, but I think you've identified the problem. Now that you've been cutting on it, is there a known surface left for you to re-indicate if removal from the current setup is required? I believe you're going to have to do that.
  11. #9
    Jul 2018
    33
    14
    5
    Yes - I made a cut about 80% across the pocket before switching to the 4 jaw and re-indexed off that.. so managed to finish it up with some chatter but was quite a task.. kept trying to grind bits for the aluminum and got very mixed results. Eventually an old bit made a beautiful finish but I couldnt get it into that tight 90 degree corner so just sanded the metal down by hand-
    as you can see the finish was pitiful but i was on the last pass and had to use as is... after sanding down it looks fine - nice and smooth..
    another issue is I cut into a jacket so not even sure if this is usable as is anymore
  12. #10
    Apr 2010
    northeastern Pa, USA
    952
    187
    276
    What I see for your cutting bit is HSS with a large round nose. Ugh!! If it was me I would have a very sharp HSS with a very positive rake. It works quite well for aluminum. Remember that the outer diameter of that piece is traveling very fast. With that many interruptions my opinion is sharp is better not a big round nose.
  13. #11
    Feb 2007
    St. George, Utah
    1,491
    999
    1039
    Well, shoot! All that work and you punch through at the end. But... unless that hole intersects a casting void you are very thin in other places too, perhaps all the way around. That can be difficult to determine. I would not proceed without addressing that first. You may be able to TIG that hole up and re-machine if it is a 'loner'.
  14. #12
    Feb 2015
    Florida
    1,151
    350
    My guess is that your interrupted cuts are setting up a vibration in your work that is throwing everything off.
