Thread: Serial Numbers Wanted
01-12-2021, 05:40 PM #2461
01-13-2021, 02:46 PM #2462
SN----------------Ship Date---Year--Notes---Size---Bed-code--Series-----------------Model---------------------Drive-----Apron---Gearing
25497NAR9--09/27/1951--1951--card---9-x-3.5----Z---------Workshop9A-------CL744Z-16spd-V-Belt--VHMD----FFA-------QCG
25500N-------------------------1951-----------9 x---------------------------------------------------------------------------------------------------------
25538NAR9--------------------1951-----------9-x-3.5----Z---------Workshop9A-------CL644Z-12spd------------HMD-----FFA-------QCG
25560NBR7--10/18/1951--1951--notes--9-x-3.5----Z---------Workshop9B-------CL377ZN----------------MCBUD---FFA---------SCG
Thanks for the numbers!!
Steve
01-13-2021, 03:44 PM #2463
55533NKR9
1966/1967
9 x 3.5
Workshop-9A
CL344-ZD 12spd
MCB-UD (Metal Cabinet Bench Under Drive)
FFA
QCG
36277K
Aprox late 1979
10 x 4.5
10K Gap Bed Metric
CL670-RGM 12spd
HMD
FFA
QCG
30221KAR
1972
10 x 3.5
10K
CL670-Z 12spd
HMD
FFA
QCG
Sorry I cant get any closer on the dates.
Thanks for the numbers,
Steve
01-13-2021, 03:53 PM #2464
01-13-2021, 05:17 PM #2465
14287RKX16
1964
10 x 4
Series S 10L Tool room
CL8187-AB
MCB-UMD
FFA
QCG
Link to possible parts sources:
www.wswells.com/download/vendor-contacts.doc
Steve
01-13-2021, 05:41 PM #2466
Bssc liked this post
01-13-2021, 05:58 PM #2467
Read these pages to see the differences between the 405(No 5), and the 415(No 15) These two preceeded the Model C released in 1938.
Model ID-Image slider
Steve
01-13-2021, 06:29 PM #2468
I would really check the motor plates and confirm the southern Island power, it should be 60hz, but don't take my word for it if you are still over there.
The northern part of the mainland was 50hz and southern is like the USA, 60hz.
The general later year 13's had motors in 1hp, 1-1/2hp, and dual voltage motors of 1-1/2hp-3/4hp, and 2hp-1hp.
If there is any question on the motor and it'is 60hz, I'd use a 3ph 2hp with VFD.
Steve
01-13-2021, 06:45 PM #2469
01-18-2021, 04:40 PM #2470
took me a while but I came to a similar conclusion 34/35 for a year OG plate is missing I have two replacements that came with it it also came with metric gears and standard gears , as it sits now I just need to clean the drive , replace the thrust bearing, and some more little stuff that can be done as it goes back togather
Flute Maker liked this post
