Rudd
Stainless
- Jul 30, 2003
- savannah, jaw-ja
I fitted a TA to my 13 specifically to turn B&S 9 tooling for my mills. I have tried the "indicate off a known good taper" method, I've tried indicating off something straight like the tailstock barrel. Even when it looks right on the indicator, the actual cut seems to be slightly off.
I could adjust for this by indicating the taper and taking another light pass, but the TA adjustment method seems to be "unsnug bolt, tap with small wrench, snug bolt, see what that did". I seem to be circling the correct .0417"/inch taper, always a bit under or over.
Has anyone come up with a better way to set the bar? Some sort of mod where you can adjust the angle of the bar with a screw for example?
