Zip
- May 25, 2007
- Champlain, NY
If one was to swap the 3 phase motor in a Heavy 10 for a 110 or 220 single phase which frame/motor would be the correct one.
None ... . . . .. . . . .use a VFD. Single phase motors cause finish issues in high gear because the motor accelerates and decelerates several times in a single motor revolution.If one was to swap the 3 phase motor in a Heavy 10 for a 110 or 220 single phase which frame/motor would be the correct one.
What source is required to run the VFD 110v or 220v?
3/4 HP is all the flat belt can couple. You should buy a VFD that will handle 2HP.
