New to this web site. Working on my South Bend 10K lathe that I bought last fall. It's in fair shape just repairing a few items. The main issue is that
someone had replaced the lead screw with a threaded rod. I have a replacement and my issue is the gear inside the quick change gearbox that drives the lead screw is not original. The one that was in there is 18 tooth gear not sure if that is correct. The parts list calls out part number PT628NK1 it's the same on 9" lathes.
Was wondering in someone might have 1 or could give any info like number of teeth or dimensions of that gear. Here's a picture of lathe and serial card
Thanks Jeff
Thanks Jeff
