Hello. I have done some searching on this forum and not located anything that seems match my machine. I am looking for a gear for my 1933 13" South Bend Lathe. The gear I'm looking for is in the drive train that powers the quick change gear box. I believe this gear is called the primary gear, and mates to the slide gear. The gear has the numbers 13-652 cast into it. It has 64 teeth, is 1/2" wide, 4.75" diameter, and according to my calculations is 14 DP. The bore is 1.25", and it is pressed onto a shaft with a round key. The catalog number for this lathe is 386-B, and I haven't been able to locate this catalog to possibly find another number besides the one on the gear. If it helps, this model has what I believe South Bend called the Silent Chain Motor Drive. I am not a machinist, so I may be using incorrect terminology; my apologies if some of these terms are incorrect. If anyone has any information on how I might locate a gear, I would definitely appreciate it. I can post pictures of the gear and lathe if that would help. There is a lot of wonderful information on this site, and I appreciate how helpful the posts have been to me in the past. Thanks!
