brovoechoseirra
- Oct 6, 2020
Hello Everyone,
I posted a few questions a while back regarding a 16 x 60 tool room lathe that I had purchased. Other work had got between me and getting the new motor installed, so it has just been sitting.
So last week, I had some time to work, and my buddy and I started to install the new motor last Friday.
We were prepared to have to do a few mods, as the new motor had different mounting holes.
However, We discovered the original pulley for the motor was not correct, or even close. It is a two grove pulley, and the belt groves are not spaced the same as the ones on the driven pulley.
Apparently when the original motor was removed, the original pulley was swapped. At some time the lathe was probably being used with this mis-matched pulley, but how successfully, we dont know.
The belt alignment would have been pretty bad, and belt life would be short the way it is now.
My buddy did some research, and it appears that there were many options on sizes. He thinks that for most of the work we will do, we need a chuck speed of about 650 on the top end.
Does any one know what size this pulley should be to achieve a speed in this range?
Or even better, if we can buy a pulley?
I was hoping that some one might be able to measure their drive, as well as driven pulley and let me know what size these are?
Also, does any one know if these lathes ran 4 belts, or less? Since the driven pulley has 4 grooves, I suppose they used them all?
Thank you for any help that anyone can offer.
BES
BES
