South Bend 16 Toolroom Lathe - The Adventure Begins... - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
  1. #41
    Jan 2019
    Hawaii
    85
    37
    19
    Progress slowed a bit since I picked up a big old Wilton C2 vise that needed some attention. Sort of overdid it a bit with "restoring it" but I figured I will be using it a lot as I move forward with the lathe. I did have a question about my lathe though. Is there supposed to be a cover here?
  2. Likes thomasutley liked this post
  3. #42
    Sep 2014
    Arizona
    799
    572
    260
    Quote Originally Posted by Kevin T View Post
    They weren't always there, but would be an easy add. I may even have an extra kicking around in my donor parts bin somewhere.
    BTW, don't let the extra "bump" on the bullgear cover throw you off. That's not from the factory. It's my own design, a cast iron cover to protect my analog tachometer pickup unit that counts bullgear teeth as they pass by below.
  4. Likes Kevin T liked this post
  5. #43
    Jan 2019
    Hawaii
    85
    37
    19
    I am getting to the business end of my lathe and got the gear cover off and found a damaged tooth on the main tumbler gearbox gear. Also I have questions about the misalignment of the gears shown below? Do I need to address the alignment? How about the bad tooth?
  6. #44
    Jan 2019
    Hawaii
    85
    37
    19
    Well the lack of response put me in the mood to search out a replacement gear. I saw one on ebay for a 14 1/2 lathe and the dims seemed to match so I went for it and it looks right! I haven't checked the bore dia of the one on the machine but the teeth and OD are a match!
  7. #45
    Jan 2019
    Hawaii
    85
    37
    19
    I tried to start following the book I bought to renovate my lathe...or at least go through the wick replacement and some cleaning and hit a snag right off the bat. My 16" looks nothing like the reference pictures in the book. I want to remove the first lower assembly of gears but do not see directions of how to get the big gear off the bottom! I am assuming that this is step one and is not shown in that book! I can't be the first to have this issue so if someone has a link to a video or a thread about how to take it off I would appreciate it. I will post pics to help my quest tomorrow.
  8. #46
    Sep 2010
    moscow,ohio
    5,523
    523
    1705
    look at the parts diagram, I believe it will answer your questions.
    BTW- Your lead gear looks like it needs a spacer behind it.
  9. #47
    Jan 2019
    Hawaii
    85
    37
    19
    Quote Originally Posted by iwananew10K View Post
    I was all set up to just drone ahead and follow the book word for word but I suspect you are right that there will be thinking involved! LOL
    For me I am looking at a damaged gear that I want to remove so I can get to the gear train below it, and unsure how to best do it? Did someone try before me and that is why the tooth is damaged? I also want to make sure that it isn't a left hand thread! The book says all nuts are right hand thread unless specified then the omission creates some doubt.
    Is the correct way to put a strap wrench on the gear OD and use a big breaker bar on that nut? or
    Do the holes in that gear serve as a way to hold it by use of a dowel/rod/heavy screwdriver through one of the holes?
    Is there a "special" tool?
    I realize I could be over thinking it but I don't want to make a costly mistake right off the bat.
    I am thinking that maybe someone purposely moved the gear to clear that damaged tooth area. I will be correcting this upon re-assembly.
  10. #48
    Sep 2010
    moscow,ohio
    5,523
    523
    1705
    i didn't even see the broken tooth! shame on me.
    i would feel better with a replacement too.
    fix the old one later and have a spare.
    as for removing the old gear getting the nut off was never a problem I ran into, but erring on the side of caution i think your strap wrench is a good plan if it seems stiff.
    can you put the sliding gear "in between" with it free spinning so no stress on it or any other gears while you remove the nut? or drop.the banjo out of mesh.
  11. #49
    Jan 2019
    Hawaii
    85
    37
    19
    Strap wrench did the trick but it was a tough cookie!
  12. Likes Sachmanram liked this post
  13. #50
    Nov 2008
    Madera county california usa
    2,304
    20
    558
    We use impact wrench with the heat held with rag...not engaged.
    Zips off fast.
  14. #51
    Jan 2019
    Hawaii
    85
    37
    19
    Quote Originally Posted by Tony Quiring View Post
    Zips off fast.
    Ahh, no impact wrench in my shop. I will be looking for a torque value when I put it on too! lol
  15. #52
    Feb 2017
    19
    22
    Just stumbled onto your thread. Great score. I just finished my 16/24. I did a bunch of the same things you did. Ask away if you have any questions and I will do my best to answer "How I did that"
    Good luck and have fun with it. I sure did.
    Here it mine. I am in the process of finding a 4 jaw chuck and Tool post holders
