South Bend 9 inch lathe
Results 1 to 15 of 15
    Dec 2018
    Kansas
    Default South Bend 9 inch lathe
    i am trying to disassemble my father's SB lathe. I am not sure of the proper name but the the upper most part that holds the tool is broken and I want to replace it. SB Co. was no help. There is a set screw in the indexed knob-crank- dial or what ever it is called. I cannot get it out even though I soaked it with Liquid Wrench. Does that screw need to be removed? I hate to try to drill it or use heat. any help will be appreciated. thks in advance Jim
    Feb 2006
    Indiana
    12,577
    594
    3586
    Jul 2003
    savannah, jaw-ja
    1,677
    1060
    380
    Two things:
    1.We have a South Bend forum, you need to post this over there.
    2. You should post a photo of what you are talking about. I cannot make sense of it.
    Feb 2011
    1,862
    1124
    771
    Any pictures? The part that holds the tool would be called a tool post. If the set screw(s) are broken, I'd assume they are tightened down too much and I doubt penetrating oil alone will help. Drilling it out down to the tool may release enough pressure and spin right out.
    Feb 2015
    Florida
    261
    45
    Quote Originally Posted by James Shepherd View Post
    Wow... there is this new technology thing called a camera that takes a still picture of items you are trying to describe. I haven't had a chance to get my hands on one yet, but I hope to in the near future. You might try to get your hands on one of those things and USE IT!
    Nov 2018
    Illinois
    6
    5
    Hello James, I'm new here also.
    I've just disassembled a 9" so I might be able to help a little.
    May 2012
    Indiana
    949
    175
    347
    Pictures would help quite a bit since you are not sure of the lathe part names. I agree, it is difficult to know what for sure you are referring to. For example Neagle responds regarding the tool post where I was interpreting your request about the compound and compound feed screw. Perhaps one of the Southbend lathe members can direct you to a diagram of parts specific to your lathe. Using the correct part names is essential to good communication and will result in better more direct responses.
    Also look for a book called “How to Run a Lathe” by Southbend lathe company. Here is a link:
    http://vintagemachinery.org/pubs/1617/3789.pdf
    There are also newer editions.
    Sep 2010
    moscow,ohio
    5,578
    540
    1760
    we also don't know what model of 9"- some of the early feed screws/bushings were pinned in place.
    A pic is sorely needed.
    Aug 2013
    796
    479
    216
  10. Likes Ram Diesel Tech liked this post
  11. #10
    Oct 2015
    Virginia
    462
    14
    98
    Guys, it is pretty clear what he is talking about. A set screw in an indexed knob-crank-dial. It is the set screw on the compound dial that locks the dial to the crank. Someone along the way probably replaced the knurled thumb screw with a set screw. I've seen that before.
    IIRC, it does not need to be removed, but you do need to loosen and unscrew the bushing to get the screw assembly out of the compound.
    What good does being snarky to a new guy do?
  12. Likes Blob, Ram Diesel Tech liked this post
  13. #11
    Jun 2012
    Michigan
    9,302
    3163
    3345
    QT Op: [i am trying to disassemble my father's SB lathe.]
    If you don't even know the name of the what is it then you are not qualified to tear it down.. better stop before you break something.
  14. #12
    Jan 2014
    Utah
    442
    1057
    171
    Quote Originally Posted by michiganbuck View Post
    Like the left hand screw, for example.
  15. #13
    Jun 2012
    Michigan
    9,302
    3163
    3345
  16. Likes Ram Diesel Tech liked this post
  17. #14
    Jul 2008
    South Carolina
    552
    163
    310
    Come on guys (the snarky ones) cut him some slack. He may be a little green, but trying to learn. He seems fairly well spoken and polite.
  18. Likes tim9lives liked this post
  19. #15
    Nov 2018
    Illinois
    6
    5
    I've been a mechanic for over 30 years and wouldn't dream of saying I knew everything about cars. I'm learning every day, and teaching the younger guys. I find that I can learn as much or by helping them as I could learn by reading or other ways of obtaining knowledge. When I was a teenager I learned by taking things apart and figuring out how they work, still do. If I broke something in the process that meant I had to learn how to fix it. Drill, easy out. Drill out broken easy out, ect… That being said, I can appreciate how some people feel when others that don't know ask what seem to be silly questions. I then ask; How are they supposed to find the correct answers? Or where to find the correct answers?
    I purchased an old 9" that I had to take apart to get in my basement. I didn't even know it was an SB lathe until I starting cleaning it up. Then I found this treasure trove of information called The Practical Machinist Forum and have already get helped by some very fine people. Swells put up a link to the "How to Run a Lathe" from 1930. The year my lathe had been built. I had no idea where to find this type of information without his help. Didn't even know it existed.
    Sorry for the long rant, but I see that James only has the 1 post. Which means he may not be back. He may have had information that could have helped the next guy.
  20. Likes tim9lives liked this post
