I purchased this old South Bend 9" lathe about a year ago. I paid $750 for it(probably too much) and didn't really know anything about it. I took by (ex)bosses word that it was good. It came with a fair amount of tools so I figured it was an OK deal.
I have spent the last month disassembling it. I have been using electrolysis, POR-15 degreaser and lots of scrubbing and polishing to slowly get it back to being functional.
I purchased the manual and rebuild kit for the lathe and I'm on the home stretch to getting is going again. I'm now at a point where I need to track down a couple small parts and some items to get things shimmed up and tight again.
The bed on my lathe is stamped U.S. Navy and it has a War tag and some stenciled Navy Symbols on it.
Serial #138142
Cat# 677Y
3' Bed
Best I can tell it's a 1943 South Bend 9b
I'm in need of a Hand wheel pinion spring (Part# 89b), a back gear, (one tooth missing)and a back gear friction spring. I had tossed a paper towel with the spring in my wood stove, only to remember a couple days later. I sifted through all the ash and found it but I'm afraid it has lost it's temper. I also need to purchase the take up bearing, thrust collar bearing, a motor with the correct bolt pattern and belt. I did track down some belt part numbers searching on here.
So here's my refurb. I will be asking some questions as I go, and hopefully y'all can help me.
Serial #138142
Cat# 677Y
3' Bed
