South Bend 9A Adjustment Question
Likes Likes:  0
Results 1 to 4 of 4
    Jun 2014
    Merchantville, NJ
    75
    17
    6
    Default South Bend 9A Adjustment Question
    Simple question- How can I tighten the wing handle for the compound feed on the crossfeed on my 9A? I notice I'll set it, next thing I know, it is dropping back out of position- no friction holding it in place... I tried tightening the weird nut in the handle, but no soap...
    Scott
    Jul 2010
    Virginia, USA
    3,548
    87
    686
    Tighten the gib strip screws on the side of the compound slightly. Also determine if cutting forces are to blame. If you are boring for instance, you have to take up the backlash by withdrawing the compound, instead of feeding inward.
    allan
    Jun 2014
    Merchantville, NJ
    75
    17
    6
    Quote Originally Posted by kitno455 View Post
    allan
    Thanks, Allen- I'll give them a shot!
    Scott
    Jun 2014
    Merchantville, NJ
    75
    17
    6
    Yep- That helped a good bit... Got started practicing threading- At this point, I'm simply getting the process down: Starting to get the hang of it. I haven't really gone for an exact dimension yet- simply trueing the round stock, then cutting a thread onto it... Then trimming it back off, and doing another thread... I've cut about 6 so far- a few more times, and I may have my 1" rod stock practice piece down to a 1/4-20... Then more practice...
    Scott
