Hi,
After converting my 9C to a 9A I found out the gear box leaks oil badly.
Replacing the sinter bushings and felts does not impact the oil leak.
So now I am considering two actions and need some advice ...
1) Does anyone know what kind of steel the gear shafts are made off?
2) Does anyone have any thoughts or advice on how to properly align the bore the gear shaft casing on the "non-sinter" bushed shaft end?
Thank you
Rover
Thank you
Rover
