(608)Fabrication
- Apr 27, 2019
First of all, I am new to Lathes and this web site. I just recently bought a 9"x36" South Bend Lathe Model C, Serial Number 178409. My guess is that it is from 1947 based off the serial number and when they changed them. I ordered the serial number ID card from grizzly and waiting on it yet. My dilemma is that the motor was not connected to the forward reverse switch drum, or the lathe at that matter, and I wasn't able to see the motor operate. This might not be the original motor based on the motor mount holes for the drive pulley, they don't match and new holes where taped. The motor is listed as GE A/C motor, 1/3hp, single phase, type KC, 1725rpm, 115/230volts, 4.8/2.4amp, 60 cycle, GEJ 789, 40 degree C temp rise, continuous time rating, clock wise. The motor is missing the cover plate for the terminals which I hear haves the wiring diagram for the drum switch. I would like to use this motor, if possible, but can't find any information on how to wire this set up together. Question 1: I need the wire diagram from the motor to switch drum and service? Question 2: Alternative motor options if Question 1 fails? Thanks for your time and help!
