South Bend drawbar disassembly problem....
Results 1 to 4 of 4
    Nov 2019
    Connecticut
    19
    Default South Bend drawbar disassembly problem....
    [ATTACH=CONFIG]271725
    I am trying to remove the tube from my heavy 10 5C drawbar. The manual shows two pins need to be removed. However, they are/were in what look(ed) like blind holes. The bearing assembly has holes but they don't go through the tube. I drilled out what should have been the pins and even went through the tube in both places. I opened the holes up to 5/16 and don't feel I should have to go any larger. I made a puller and tried to put quite a bit of pressure on it to pull off the bearing assembly. It didn't budge. I am afraid of using heat because there is a bearing inside. Does anyone have any suggestions? Thank you.
    Jul 2003
    savannah, jaw-ja
    1,747
    1214
    414
    I suggest this post be moved to the SB forum where it will get the proper attention.
    Nov 2019
    Connecticut
    19
    Thank you. I'm rather new here. I didn't realize that there was a SB area. Perhaps I can move it myself by copying it there and then deleting it. Here goes....
    Nov 2019
    Connecticut
    19
    Got it apart.... finally, needed a little heat and then cooling to loosen it enough for my puller to get it to budge.
  5. Likes Dumpster_diving liked this post
