Southbend 10L lathe parts needed
Results 1 to 15 of 15
    Sep 2019
    8
    Default Southbend 10L lathe parts needed
    I just inherited a southbend 10L lathe, I need the gears that drive the gear box. I'm not sure about which gears I need because I haven't found a parts manual. Any help will be greatly appreciated. I want to get her back in working order.
    Jan 2019
    North Carolina
    228
    26
    39
    Hi Eric, I’m on mobile or i’d Link it for you. But in the sticky topics in this sub forum one is asking for serial numbers. If you go to that topic, the second post has a link to Steve wells website. There click on the parts section and you can find most parts breakdowns for any machine you’d like though some things are missing.
    Depending on which gears you need and if you are unable to find them I can supply you with new ones. You may be able to find them on eBay though, 10L parts are usually pretty easy to find.
    Stephen
    Oct 2015
    Virginia
    551
    18
    127
    The 56 goes on the gearbox, the 80 goes on the banjo idler. Both are on eBay I’m sure. I think I saw damienpdr list some yesterday.
    Edited to add: that’s for a double tumbler machine. I can’t read your serial card on my phone so I don’t know what style you have.
    Sep 2019
    8
    It's a single tumbler, but thank you for the info.
    Sep 2019
    8
    here is what I 20190925_084932.jpghave, not sure what all is missing
    Sep 2010
    moscow,ohio
    5,918
    579
    1893
    you are missing the-
    banjo assembly with the primary and sliding gears
    banjo bed bracket
    Gearbox input gear(64T)
    before you start sinking money tho, would advise a strip down to basic components to evaluate if the machine is worth it.
    Most notably the gearbox and apron...that machine looks to have been sitting for a very long time....
    Sep 2019
    8
    it has been sitting for a while, and has a lot of play in the cross slide etc... I got it for free so I don't mind putting some money into it.
    Jan 2019
    North Carolina
    228
    26
    39
    If you want to get rid of some of that play in the cross slide, I can definitely help you with that!
    Sep 2019
    8
    parts can you help me with, I'm still confused at what specific parts I need.
    Jan 2019
    North Carolina
    228
    26
    39
    Quote Originally Posted by edoskocil View Post
    Well, it really depends on what is causing the play, if its side to side, or in the ways, make sure your gib is sufficiently tight with the adjustment screw which is on the cross slide to the upper right hand side of the dovetail. If it's backlash in the handle, that's likely a worn nut or screw, I make replacements that I can supply you with. If it's endplay it could be any number of things that have wear or aren't tightened as they should be. Look over the cross slide and do a couple things:
    1. See if you can push the cross slide forward and back on the dovetail by hand. Actually put your hands on the compound and try to wiggle it. If it has a lot of wiggle in it, check and make sure everything is tightened appropriately. Also try to wiggle it side to side and see if it has any major movement.
    2. turn the cross slide handle one direction till the compound moves then turn it the same direction to zero. then reverse direction turning the handle slowly until the cross slide moves in the other direction. This is the backlash of your screw.
  11. #11
    Sep 2019
    8
    The cross feed screw and nut are worn, I have parts on order for that. Still trying to find the gears I need
  12. #12
    Jan 2019
    North Carolina
    228
    26
    39
    I didn’t even notice the name, thanks for the purchase! If you can give me the part numbers for the gears I’ll take a look when I get home.
  13. #13
    Sep 2010
    moscow,ohio
    5,918
    579
    1893
    maybe the easiest thing you can do is send Ted and email, include pic and he will know exactly what you need, and likely can supply the pieces....one stop shopping will save you from multiple shipping costs.
    [email protected]
  14. Likes edoskocil liked this post
  15. #14
    Sep 2004
    Fort Worth, Texas
    2,145
    275
    186
    I have a banjo if you need that.
  16. #15
    Sep 2019
    8
    I do need it, can you give me a call 817-933-7113, or I can call you. THANKS!
