Southbend 9 inch quick chaNGE QUESTION.
Results 1 to 9 of 9
    May 2020
    5
    Default Southbend 9 inch quick chaNGE QUESTION.
    I HAVE an old Southy with a quick change gearbox. It requires loosening a set screw to engage the feed screw. A long time ago I saw an article on how to install the newer quick pull assembly. I bought it and printed the diagram on the piece I have to make with the indent holes for this to work. I lost the diagram. Does any one have a copy?
    Feb 2015
    Florida
    661
    166
    Again, you're going to have to be more specific. You probably don't know the correct terminology, so your posts basically don't make a whole lot of sense. Take a picture of what your problem is and post them with your questions. Be sure the pictures are clear and in focus and are posted FULL SIZE. I've never heard of a feed screw needing a set screw loosened in order for it to operate.
    Jul 2004
    Houston, TX USA
    30,729
    Maybe he refers to series O where you have to unscrew the feed select knob (with the star) to get it in neutral where you can use the lead screw for threading
    Item X on page 5
    http://vintagemachinery.org/pubs/1617/5795.pdf
    Sep 2010
    moscow,ohio
    6,281
    643
    2073
    i think hes referring to the feed reverse tumbler assby mod thing.
    from a bolt down reverser to a pull pin detent style like on a 10K model.
    just me but IMO its a step backwards...you can simply make an extension to the head of the hold down bolt, which functionally is as convenient as the pull pin style, but more stable and retains the ablility to independently adjust the mesh of the two tumbler gears via the set screws of the bolt down style reverser.
    of course thats just personal opinion.
    Feb 2004
    peekskill, NY
    25,098
    5007
    I always thought the bolt-down reversing tumbler was a wise move by SB - they were aware that novices would be less likely to try
    shifting those under power, needing a wrench and all.
    Nov 2007
    Houston, Texas
    256
    70
    49
    Quote Originally Posted by jim rozen View Post
    I was looking at those pin type reverse gear tumblers just from a curiosity standpoint as I see them on FleaBay.
    But I don't have that kind of need to immediately change gear directions, and the bolt type is fine with me.
    However, isn't there a mating piece on the casting of the headstock for this option? Those pins have to index
    somewhere on the lathe, and I've never seen the mating part. Again, just curious.
    I've seen them on the 10K models, but not 9".
    PMc
    May 2020
    5
    Quote Originally Posted by iwananew10K View Post
    Reverse tumbler must be what I am talking about. The lathe at work can be shifted from neutral to reverse or forward by pulling out the lever and moving up or down. My lathe at home you need to loosen a square bolt, shift up or down and then tighten.
    Some one came up with a mod to convert mine. I bought the part but need to make a plate with holes for the pin to INDEX IN TO. Someone designed the plate and I lost the drawing.
    Jun 2013
    Buffalo NY USA
    382
    268
    184
    Quote Originally Posted by appleboxx View Post
    You can find what you're looking for in this thread: 10K Leadscrew Reverse Lever Installed on 9" ABC
  9. Likes mcload liked this post
  10. #9
    May 2020
    5
    Thank you guys for helping. The original thread I was looking for had a measured drawing but all the info I need is shown in that link. I look forward to being a member of this group
    max
