Southbend Taper Pin Part Number Cross Reference
Results 1 to 6 of 6
    Dec 2008
    North Carolina
    685
    200
    158
    Default Southbend Taper Pin Part Number Cross Reference
    Does any one have a cross reference of Southbend taper pin part numbers to the standard number equivalent?
    What is a 168x516 taper pin?
    What is a 168x307 taper pin?
    What is a 168x513 taper pin?
    These taper pins are found on the bent pipe heavy 10 cabinet under drive. I'm sure that I will come across other number as a proceed with the cleaning and re-wicking of my heavy 10.
    Vlad
    Dec 2004
    Indiana
    1,638
    447
    159
    Vlad,
    168x307 = #2 x 7/8"
    168x513 = #4 x 1-5/8"
    168x516 = #4 x 2.0"
    Steve
    Dec 2008
    North Carolina
    685
    200
    158
    You da man Steve!
    Can I assume that any 168x3XX will be a #2 pin, that any 168x5XX will be a #4 pin?
    By deduction then a 168x1XX will be a #0 pin, a 168x2XX will be a #1 pin, 168x4XX will be a #3 pin, 168x6XX will be a #5 pin, etc?
    And the last two digits of the part number would be the length in 1/8" over one inch if the number is 168xX1X and the number of 1/8" less than one inch if the number is 168xX0X?
    Vlad
    Jul 2008
    South Bend, In
    2,657
    169
    265
    South Bend Lathe “X” numbers;
    Commercially Available Hardware
    http://www.wewilliams.net/docs/Comme...orm%201178.pdf
  5. Likes 10KPete, Kevin T liked this post
    Dec 2004
    Indiana
    1,638
    447
    159
    Yes Vlad, that's correct. They start at 00, 0, 1, 2, 3, 4, 5, 6. = x, 1xx, 2xx, 3xx and so on.
    see the link Ted posted.
    Steve
    Dec 2008
    North Carolina
    685
    200
    158
    Thank you Steve. It looks like the manual Ted posted is from your web site. I thank both of you for the help you have provided, not only me but all of the people on this forum.
    Vlad
