spin dle swap on a O series 11"??
Likes Likes:  0
Results 1 to 5 of 5
    Oct 2017
    14
    Default spin dle swap on a O series 11"??
    spindle swap out on a 1928 O series 11" possible?
    Ive heard of this being done successfully with other series
    ive got a O series 11" but the spindle is a odd duck for tooling and the pass through is narrower than id prefer.
    anyone had any luck swapping out one if so what donor spindle did you use?
    Jul 2004
    Houston, TX USA
    29,467
    Here are a few dimension - like length. See if ANY of the lengths are anywhere near your spindle length
    Then you can wonder about essentials, like bearing diameters and cone fit diameters and bull gear fit diameter
    Oct 2017
    14
    thank you should help! was kinda hoping someone had already invented the wheel as it were heh...
    Jul 2010
    Virginia, USA
    3,417
    86
    616
    I'd guess you've got no chance on this. Those spindles are heavy walled because they are soft, and the later lathes have drastically different headstocks.
    allan
    Jul 2004
    Houston, TX USA
    29,467
    If I just HAD to have a different spindle, I would have the old one out and make a dimensioned drawing of it and go from there. Its what machinists do.
