Spindle Bearings for 1979 Heavy 10
Results 1 to 12 of 12
    Mar 2019
    Indiana
    5
    Default Spindle Bearings for 1979 Heavy 10
    I have a heavy 10 with scored bearings I am restoring. Serial number 21394R. The shaft is badly scored and I am having it chromed and reground to size. I called grizzly and they want a part number that I donít have, and I checked with Ted (sblatheman) and there are none available through him. Does anyone have a part number or a new set of spindle bearings that I could get? I donít have the facilities to tin or Babbitt and remachine without the lathe accurately.
    Ron
    Feb 2015
    Florida
    261
    45
    The rear bearing is AS512R2.
    The front bearing is AS511R2.
    Mar 2019
    Indiana
    5
    Thank you slk001, I will check tomorrow
    Sep 2010
    moscow,ohio
    5,574
    540
    1757
    have you tried just setting clearances and running it?
    these things are quite forgiving.
    Mar 2019
    Indiana
    5
    Yes it had runout and I donít have shims left to remove. I tried grizzly, blue mountain, and sblatheman. No one has bearings. I would like to resurface and chrome plate the shaft to repair. Does anyone have the spindle to bearing clearance for a new bearing?
    Oct 2015
    Virginia
    462
    14
    98
    You don’t have any shims to remove? Does this mean you do not have any shims in at all, or you can’t reduce the thickness of the ones you have? Original shims were .018” thick.
    A member here, FSH, sells laminated shims on eBay. I recommend them.
    Jan 2014
    North Carolina
    416
    15
    108
    If you have spindle run-out with the set-up you have, that's the fault of the spindle, not the bearing inserts. Chroming and re-grinding should fix the run-out. BUT make sure the spindle bearings are ground relative to the bore of the spindle and not "free form" in a centerless grinder because you could end up with run-out of the spindle bore if you're not careful about that.
    Bearing clearance should be .001 to .0015 if memory serves. You could get away with a little more than that. With a hard chrome bearing surface on the spindle, you should try running in the bearings you have because even though the bearing surfaces may be scored, they're not likely to damage the spindle for a long, long time and you would probably find that you have acceptable performance that way.
    Mar 2019
    Indiana
    5
    Thanks for the responses and clearance numbers they are much appreciated
    Nov 2008
    Madera county california usa
    2,333
    20
    571
    If you are chrome plating spindle then can it be chromed oversize to work in existing bearings?
    Jul 2010
    Virginia, USA
    3,381
    85
    601
    Frankly. you can probably replace the spindle with one from ebay for cheaper than you can have your existing one fixed...
    allan
  11. Likes Dobermann liked this post
  12. #11
    Sep 2010
    moscow,ohio
    5,574
    540
    1757
    ^^ true that!
  13. #12
    Mar 2019
    Indiana
    5
    Probably true. I will keep an eye out on eBay and see about getting the existing one reconditioned as well.
