kevinmdudley
- Oct 8, 2019
I had initially used published charts, of course they were not accurate for "MY" pulleys etc....
I also found one well published chart from a tool manufacturer with "Transcribed Errors" BIG ONES!
I found at LOW rpms, 80-90 I could just put a finger on the chuck and count the passing adjuster for one minute but this did not help for the other higher rpms.
I could not count that fast!!!!!
That being said, I am a stickler for finding the true results of ANYTHING mechanical like this.
I wanted to KNOW the spindle RPM for ALL my gears SB 10K 12 speed.
If finally dawned on me and "I'm SURE" other but thought I would share anyhow.
If you have a gear box and can "setup" known THREADS PER INCH (revolutions per inch) you can easily and have fun figuring it out yourself!
My explanation and examples follow.
I set my gear change box to 20 threads per inch.
Engaged halfnuts and timed for a distance. Measured from tailstock.
Length of time does not matter but LONGER DISTANCE is more accurate!
If you CAN go for 1 minute then RPM's equals inches traveled X TPI!
Measure the distance
Apply Time vs Distance formula against threads per inch (revolutions per inch)
Formula:
(Measured Distance Carriage Traveled) X (Threads Per Inch) = Total revolutions
(60 seconds) / (Time Of Carriage Movement in seconds) = Time Factor
(Total Revolutions) X (Time Factor) = RPM
EXAMPLE:
Measured Distance Carriage Traveled = 24”
Time of Carriage Movement = 45 seconds
Threads Per Inch = 20TPI
24” X 20TPI = 480 revolutions.
60 / 45 = 1.33 (TIME FACTOR)
480 X 1.33 = 638.4 RPM
Or if carriage movement time was 2:00 min (120 sec)
60 / 120 = 0.5 (TIME FACTOR)
480 X 0.5 = 240.0 RPM
This is not complicated and after figuring a couple I could just do them on my phone as I tested.
I felt stupid for not realizing this early on.
Some people have used/bought instruments to get RPM live well..... no need really!
Hope it helps others.
Not that RPM is the end of the world but it's NICE TO KNOW "what gear to change to" to be in the desired cutting speed.
Thanks...
Formula:
EXAMPLE:
Thanks...
