plinkerton
- Aug 25, 2018
Hi All,
I just pulled all the old 16/6 SO (it got pinched, long story) and replaced it with new 14/6 SOOW. This is from the motor to the junction box, and from the box to the motor. The motor is a 3/4hp GE 115v 5 lead (no thermal protection)5KC45PG183A. The drum switch is a Triple pole double throw Cutler-Hammer. I never had a chance to see if this lathe ran before it was disassembled, so I'm taking the wiring with a grain of salt.
I wired it the same way it was wired before and it will run in forward, and buzz in reverse. The reason I'm posting this is because I've dug through this forum and not found a wiring diagram that matches the one on the inside cover of this GE motor. Picture below, with redrawn diagram:
To make things a little more complicated the wiring diagram on the motor is upside down when compared to the actual switch. The switch has three jumpers (highlighted in blue) one of which is soldered in from the factory, which is why I say it is upside down. Currently how it is wired:
In addition, It looks as if two original jumpers that were soldered in have been cut out and replaced with solid core wire to match the wiring diagram on the motor. Switch jumpers below:
As near as I can tell the numbers match up even those these diagrams are different CW: (2&6 to Neutral) (5 to 4 Hot). CCW (5&6 to Neutral) (1 to 4 Hot)
Hopefully these pictures shed some light on what I'm talking about. If anyone has any ideas as to whats going on in reverse please let me know...
