Tail Stock Alignment Help - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Apr 2010
    northeastern Pa, USA
    599
    106
    166
    The OP has a .200 difference. That is not wear by any means. Usually you see .006 to .010 wear in the base. His base doesn't look that worn. Something is amiss.
  2. #22
    Sep 2015
    Florida
    594
    85
    Quote Originally Posted by tommy1010 View Post
    I get that.
    He said he intends to shim nonetheless in the short term- and odds are that the current base,correct or not, has wear that will be "uneven", and accounted for when bringing to correct height.
  3. #23
    Oct 2019
    Massachusetts
    21
    I will shim in the short time. I am going to measure the base with a drop indicator and aim accordingly.
  4. #24
    Jun 2012
    Michigan
    10,050
    3387
    3592
    Common method is to turn a slug the same size a your tail's center or the quill diameter and target them being the same height..*but good to know your quill will be true horizontal / parallel to your bed at the place of carriage /saddle travel you most often use it.
    A dial indicator would be my choice to use. Guess a test indicator would be good also...with striking across the top side.
