Tailstock handwheel installation
Likes Likes:  0
Results 1 to 3 of 3
    Feb 2015
    Georgia
    Default Tailstock handwheel installation
    I have just finished rebuilding a Heavy 10. I can not seem to figure out the proper way to reinstall the handwheel on the tailstock. I have the version with a threaded shaft that uses a small pin between the wheel and shaft. I can not get the pin to drive into the hole between the wheel and shaft. is there a trick?
    Thanks in advance for any assistance.
    Jul 2008
    South Bend, In
    2,575
    153
    234
    The HEAVY 10 has what’s called a “Dutchman Key” (a straight pin use as a key)
    If you are using the same Handwheel and screw, the half-holes should line up. They were machined together. If they aren’t a matched set, you will have to drill a new hole(keyway)
    Ted
    Sep 2010
    moscow,ohio
    5,695
    551
    1801
    I deleted my original reply...my eyes played a trick and Didn't see the heavy 10 part...
