Tailstock Tool?
Results 1 to 8 of 8
Thread: Tailstock Tool?
    Nov 2007
    Houston, Texas
    124
    35
    13
    Cool Tailstock Tool?
    I've been staring at this "tool" for decades in the lathe drawer, but for the life of me, can't figure
    out what it is or what it does. I only assume its for use in the tailstock. It doesn't spin.
    Any ideas? Custom piece? Internal pipe center? Henweigh?
    PMc
    Sep 2009
    Phoenix,AZ
    1,837
    2804
    472
    It is a "crotch"center normally use for drilling a hole in the side of a round item with a drill bit held in the headstock.
  3. Likes Illinoyance, garyphansen liked this post
    Dec 2008
    minnesota
    171
    30
    166
    I have seen it referred to as a "crotch center".
    It is used for crossdrilling a shaft with a drill chucked in the lathe spindle,
    and the shaft held in the v-groove and fed onto the drill with the tailstock.
    Nov 2007
    Houston, Texas
    124
    35
    13
    Also, a few pics of my rebuild progress.
    Nov 2007
    Houston, Texas
    124
    35
    13
    Thanks guys; both of those explanations make perfect sense now!
    Appreciate it. Guess I'll clean 'er up.
    PMc
    Feb 2015
    Florida
    529
    115
    Align the holes in your two gear shafts on the reversing gear assembly upward. The hole slopes downward toward the felts, letting the oil get to the felts, then the shafts.
    Nov 2007
    Houston, Texas
    124
    35
    13
    Default You Bet!
    Quote Originally Posted by SLK001 View Post
    Thanks for mentioning that; it was on my list. I noticed that after getting the nut tightened (the shaft did
    turn during) so knew they were prob going to be off. I decided to first set it into the lathe to see where "true"
    vertical was. Good experienced eyes!
    P Mc
  9. #8
    Nov 2007
    Houston, Texas
    124
    35
    13
    Few more:
