Rick_B
Stainless
- Sep 16, 2011
- Winston Salem, NC
It seems there are ongoing conversations around rebuilding a lathe versus a clean up, oiling and running it. I've always felt that the rebuild process served a number of purposes - clean up of decades of gunk build up, check of parts to determine what may need replaced, gain an understanding of ho the machine works and finally pretty it up.
Today I was doing some simple turning to a diameter and the power feed stopped working. Because I had torn the lathe down to every single nut and bolt and reassembled - I completely understood and had a mental picture of how that power feed worked and what was wrong. It too 20 minutes to pull the apron, remove the oil sump cover, realign the clutch plates and reassemble. Without the experience of rebuilding I would still be scratching my head and asking quesions.
Now if I could only remember to not turn that clutch know so far and allow those plates to get misaligned in the first place
Rick
Rick
