Thread Dial Casting?
Results 1 to 13 of 13
    Aug 2017
    Ohio
    109
    35
    Default Thread Dial Casting?
    Has anyone ever thought about making up some thread dial castings? Something similar to the MLA kits. I have to imagine it'd be cheaper than the $150 people ask for them on Ebay, and i'm sure lots of people would prefer that to the 3D printed version.
    Jan 2014
    North Carolina
    440
    15
    116
    Anybody with a lathe can make his/her own threading dial body. It's handy if you have a welder and milling machine but you can do it without a great deal of effort using just the lathe and 4-jaw chuck. You need a hollow member for the dial's spindle to turn in. You need either a plain spigot or flanged spigot to mount the thing on the lathe carriage--depending on the lathe it goes with. The spigot can be threaded into the main member or welded to it if you have a welder. You should have but don't have to have a shroud to keep chips and fingers out of the driven gear which meshes with lead screw. This shroud can be threaded to attach to the main member and part of it needs to be machined away to allow the gear to contact the lead screw. This can easily be done with a 4-jaw chuck. Then you need an upper piece in which the dial rotates so that you can make a place for a witness mark.
    That's it. It's a fairly straightforward lathe project. Making one yourself follows the tradition of the lathe which is an unusual machine in that it can make its own parts.
    Mar 2004
    Albertville, Alabama
    1,066
    46
    Sent a PM about the 3d print file.
    Jul 2010
    Virginia, USA
    3,418
    86
    616
    At one point, Plaza Machinery had a number of thread dial bodies cast. I don't know what happened to them after Joe died.
    allan
    Aug 2017
    Ohio
    109
    35
    Quote Originally Posted by kitno455 View Post
    allan
    That's unfortunate to hear!
    Apr 2019
    38
    Quote Originally Posted by Dobermann View Post
    Anybody with a lathe can make his/her own threading dial body. That's it. It's a fairly straightforward lathe project. Making one yourself follows the tradition of the lathe which is an unusual machine in that it can make its own parts.
    Amen. I did it and it looks better that the cast original:
    SB9A restore and retrofit 3 phase/VFD
    Jan 2014
    North Carolina
    440
    15
    116
    Wow! Nice looking job. You painted yours. Mine is still in the black oxide left over from Oxy/Acetylene welding the parts together. The finish sort of goes with what's left of the original finish on my 9 Jr.
    Sep 2005
    Connecticut
    4,478
    543
    594
    Someone is selling 3-d printed plastic ones on fleabay.
    It's not like it's a part that takes a lot of loads, so for some people, it may last as long as the machine.
    Steve
    Mar 2004
    1,066
    46
    Here is the 3d printed one I made several months back. The body is plastic (petg) all the other parts I made are steel. Works great!
    I designed this one to look more like the factory original then the one on eBay. I you want the stl file just yell.
  10. Likes mllud22, jhruska, Engmaxx liked this post
  11. #10
    Sep 2004
    Fort Worth, Texas
    2,136
    271
    183
    Grizzly makes a decent thread dial for their Taiwan 10K. The body is cast iron, everything else is steel. I have mounted one to an older 10k and last week to a Logan 12”. It can be fitted to almost anything with a 8 tpi lead screw
    they used to sell it as a kit part# PSB10020554A THREAD DIAL ASSEMBLY for $50, but I think they have dropped the kit and still sell the parts. I need to order another.
    This is the Logan, which required an offset adapter. It fits the South Bends directly. although I think I had to turn down the mounting stud slightly to fit the apron hole.
  12. #11
    Jul 2009
    Munster, In. USA
    2,270
    454
    677
    I'm gonna yell twice cause that is so durn good looking and yes to the file.
    John
  13. #12
    Nov 2016
    CANADA
    Ontario
    64
    11
    5
    Though not as good as mcruff's dial (so well done man!), I had a buddy 3D print my components from Thingiverse Southbend 9c Thread indicator one piece body by brian_groves - Thingiverse.
    Even with a mediocre print, the dial turned out really good. I made all the metal components including the drill guide on the right side of the picture. I drilled in some oil holes too.
  14. Likes jhruska liked this post
  15. #13
    Nov 2016
    CANADA
    Ontario
    64
    11
    5
