Threading problem model 9 a
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jun 2021
    Illinois
    15
    Default Threading problem model 9 a
    Set gear box to cut a 20 tpi and its cutting 15tpi. Why is this? It's my first lathe trying to learn as I go thanks
    Feb 2015
    Florida
    1,108
    331
    Quote Originally Posted by Jordan429 View Post
    Probably something to do with the gear chain at the head of your lathe. Give us a complete list of the gears in the chain and clear photos of the gearing. Most of the gears are stamped with the number of teeth, but if you can't find a number, COUNT THEM. All this assumes that there aren't any problems with your gearbox.
  3. Likes Richard King liked this post
    Jul 2004
    Houston, TX USA
    32,334
    Further to that - do you have the right stud gear installed? There are two of them to choose from
    A look at your chart on your quick change gear box in the first column on left will tell you that there are 20 tooth and 40 tooth stud gears
    Here are 12 pages of way more info on the 9A (no open? means I need your email address - which you can private message me - with something useful in the subject line - like SB 9A gearing)
    http://bnordgren.org/files/model-a-gears.pdf
    have fun
  5. Likes Richard King liked this post
  6. #4
    Jun 2021
    Indiana
    10
    Jordan, the 40 tooth stud gear cuts the tpi in half for the top row of the chart. You’d notice that large of a gear in there, and there is no 30 tpi on the chart anyway, so nothing to cut in half to get 15. Just a guess but the inner gear on the stud gear is 24 tooth (the one that contacts the reverse tumbler gears) while the outer is 20 tooth (the one that contacts the lead screw gear.) They both have the same shaft size and key way. If they were reversed it would alter the feed rate. Make sure the smaller gear is out.
  7. #5
    Apr 2009
    CA USA
    168
    24
    15
    Are you using the half nuts , or the power feed ?
    animal
  8. #6
    Jun 2021
    Illinois
    15
    Thanks. half nuts trying to get some pics not shure how to post them. Got 20 tooth on top 40 on bottom
  9. #7
    Jul 2004
    Houston, TX USA
    32,334
    One of the how-to threads on posting photos
    Posting Pictures on the South Bend Forum
    have fun
  10. #8
    Jul 2004
    Houston, TX USA
    32,334
    Note behind the stored 40 should be this gearbox gear
    This is always 56T in the model A with the English Lead Screw
  11. #9
    Feb 2018
    Iowa
    34
    6
    If your screw gear is 42 teeth instead of 56 teeth you could get 15tpi on 20. That’s what I do to get 30tpi… I use a 42 tooth for the screw gear and set the box for 40 tip. If your lathe doesn’t have a 56 tooth gear they are always available on eBay cheap.
  12. #10
    Jun 2021
    Illinois
    15
    The 40 tooth is running in line now with a 56 tooth on outside of the 40 as a spare are we saying swap the to to correct the issue
  13. #11
    Jun 2021
    Illinois
    15
    20t to an 80t to a 40t
  14. #12
    Jul 2004
    Houston, TX USA
    32,334
    Need the 56 working and the 40 stored doing nothing - if you want the threading (20 TPI) to be right
    You can fairly plainly see this in the photo in Post #3
    Or better yet from the link in Post #3
  15. #13
    Jan 2014
    Utah
    744
    1969
    370
    Quote Originally Posted by johnoder View Post
    Yes. And just as an aside, the 80 tooth gear is an idler. It can be any size that reaches and the ratio will be the same.
  16. #14
    Jun 2021
    Illinois
    15
    Going to try it thank for the help
  17. #15
    Jun 2021
    Illinois
    15
    Ok I switched the gears around and now I tried cutting a 20 tpi and it cut a 22 tpi alot closer. thought I had it, anyone have any suggestions?
  18. #16
    Jul 2004
    Houston, TX USA
    32,334
    I'll assume you actually got the 20 stud, 80 idler and 56 tooth gear box gears all on and meshing properly
    You can assure yourself it is either doing what its supposed to or not.
    Put it in 20 TPI, engage half nut and turn chuck exactly one turn after removing all lost motion - like one turn before the measuring turn
    A dial indicator set against the carriage and zeroed will move exactly .050" in that measuring turn - this is because one inch divided by 20 = .050"
  19. #17
    Jan 2005
    Victoria, Texas, USA
    4,792
    3443
    1351
    It's real easy to misread the numbers on the chart on the quick change gear box on the 9A lathe. Especially if there is any wear and tear to the plate. I've made that mistake a time or two on my 9" SBL. Older age and eye sight along with delxsus, makes it real easy to make mistakes with the placement of the lever. Ken
  20. #18
    May 2014
    Ohio
    52
    25
    Sounds like you had two problems in the beginning. The gear train should be 20 - 80 - 56 which you have corrected and got you closer. I think the second problem might be the gear attached to the end of the lead screw in the gearbox being flipped over. This thread from a little over a year ago describes the problem better than I can.
    Strange threading problem
    Hope this helps.
    Ben
  21. #19
    Jan 2014
    Utah
    744
    1969
    370
    I made this model of a 9A QCGB a couple years ago. I think you can clearly see the consequence of having the leadscrew gear reversed.
  22. #20
    Jun 2021
    Illinois
    15
    Great I'll take it apart and check out the gear👍
