bluearc
- Sep 21, 2012
- pennsylvania
How is the threading dial locked after the right number is selected to cut threads, so far I have been experimenting changing gears for different threads with coordinating the dial however, I am unable to locate info on how to lock the dial on the number selected to repeat the passes.
Having no instruction at all in the use of a lathe and being new to the SB9 I read a number of publications on the SB9 and nowhere was I able to find a step by step procedure on manually changing gears, a few illustrations and gear change charts were available, I have been a welder for years and am not unfamiliar with using shop equipment but the lathe is different territory .
So far I have been able to do a lot with it except threading.
thanks
thanks
