porthos
- Sep 12, 2013
- western pennsylvania
trying to center the tailstock with the headstock. onheavy 10 made a test bar .750 round with 1.250 collars on each end 9 in. apart in the center of the collars. got both ends to measure the same . at this time 1.220 +- .001 depending on my mike setting; but very close. however when i use a indicator on the tops of the collars; the tailstock end is around .006 higher than the headstock collar. is the tailstock too low or are the ways worn at that area??
