Upgrade Motor on SB 1002 10K Lathe
Likes Likes:  0
Results 1 to 19 of 19
    Jan 2020
    Colorado
    12
    Default Upgrade Motor on SB 1002 10K Lathe
    Hello. Any advice on the following matter would be greatly appreciated.
    I have a SB 1002 10K lathe.
    I have really enjoyed using the lathe but I find it to be underpowered. I would like to add a VFD and a Seimens servo drive motor to increase the power of the lathe. Is it possible to do this on a lathe that uses a step pulley system? Does anyone using this forum have any experience with this?
    Thanks again,
    Stephen
    Oct 2019
    CANADA
    69
    120
    29
    I have the same lathe with a 1/2 hp motor.
    Is yours a horizontal or underdrive model?
    What kind of work are you doing that 1hp is insufficient?
    Jan 2020
    Colorado
    12
    The motor is not inline with the spindle. It is mounted below and to the left.
    It does fine with softer materials but when I get into harder materials (even mild steel), it just seems like my depth of cut is very limited.
    Oct 2019
    CANADA
    69
    120
    29
    Can you post some pics of the setup?
    Jan 2020
    Colorado
    12
    Sure but I'm new this site and I'm not sure how to upload photos. Let me work on that and I'll try to get you some pics.
    Oct 2019
    CANADA
    69
    120
    29
    You can pm them to me too if that’s easier
    Jan 2020
    Colorado
    12
    Not seeing where to attach photo.
    Jan 2020
    Colorado
    12
    Oct 2019
    CANADA
    69
    120
    29
    Ok
    If you can figure out the frame size of the motor from the plate you will likely be able to source a larger Hp motor that will fit.
    But before you do that what kind of tool bits are you using and what kind of depth of cut are you attempting?
    Edit: I can see a carbide insert tool holder.
    Oct 2015
    Virginia
    576
    19
    132
    Light passes is the name of the game on something like a 9/10k. You can put a 5hp motor on there but the belts will slip before you achieve the hogging of hard materials like you have in mind.
  11. #11
    Jan 2020
    Colorado
    12
    I have an AXA quick change. Intend to go with inserts rather than HSS.https://www.practicalmachinist.com/v...attach/jpg.gif
  12. #12
    Oct 2019
    CANADA
    69
    120
    29
    You might be better served by HSS there because they require less hp.
    I use HSS on my 10K almost exclusively.
  13. #13
    Jan 2020
    Colorado
    12
    Just out of curiosity, what depth of cut are you able to achieve with your 1/2 hp on HSS?
  14. #14
    Jan 2020
    Colorado
    12
    What would you consider a light pass, for example on mild steel, 20 thousands? I’m using carbide inserts.
  15. #15
    Jan 2020
    Colorado
    12
    What would you consider a light pass to be on mild steel using carbide inserts?
  16. #16
    Oct 2019
    CANADA
    69
    120
    29
    I typically don’t go for more than .020 depth of cut in steel. I have no need to hog off deep cuts.
    My 10K is an older model with the flat belts.
  17. #17
    Nov 2017
    338
    228
    224
    I had already bought a 2 hp motor for my Heavy 10L when I decided to try a serpentine belt. I lost interest in the motor upgrade thereafter.
    Heavy 10 serpentine belt??
    To save some time, I've found that Shoe Goo is the glue to use.
  18. #18
    Oct 2019
    CANADA
    69
    120
    29
    Hey @Mrwhoppee glad to see you drop in on this.
    So the OP has a new Grizzly SB 10K not the ‘old’ style like I have.
    I’m not sure what kind of DOC he’s expecting though.
  19. #19
    Jan 2020
    Colorado
    12
    Mine is not the Heavy 10. Will the serpentine belt still work?
