EPAIII
- Nov 23, 2003
- Beaumont, TX, USA
I want to make a extension holder for 1/8" milling cutters from 3/4" ground rod on my SB-9. I have checked and the stock will fit through the spindle, but there is almost no spare space in there. So, it does not appear that a collet closer could be made to fit around the stock. But one could possibly use an internal thread on a MT collet if the stock were short enough.
I am wondering if anyone has done any work with a 3/4", MT collet on this machine? And how was it done? I would be drilling a well centered hole starting with a carbide spotting bit and then a larger bit for the full depth. Then using a reamer to get it to the exact size. Finally finishing the end with a chamfer, probably 45 degree. Could a MT collet hold it for this without using a draw bar closer?
Or am I better off just dialing it in with a four jaw chuck? Or a three jaw with true centering capability?
